0 Mid West Meet & Greet
0 No oil flow
Last Post: Kenb
0 Hello from Canada!
Last Post: SwissXL
0 Your Favorite Style
Last Post: rich56
0 Gel in seat for rigid?
Last Post: trappnman
0 Base line jetting for S&S Super with Thunderjet
Last Post: ftwflh
0 Cam position sensor
Last Post: ftwflh
Last Post: 72 Ironhead XLH
0 900cc Pistons
Last Post: mickey t
Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: RDHenley
Last Post: MkC
2 Your daily tunes...
Last Post: RDHenley
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
Old 20th February 2013
Don Burton's Avatar
Don Burton Don Burton is offline
Sportster/Buell Model: XL 1200 Gone
Don Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond reputeDon Burton has a reputation beyond repute
Originally Posted by Bone View Post
they seem to be clearly labelled Cat-con or something like that when they are equipped.
The word "Catalyst" is stamped right on them.
Don Burton's Avatar
Both of my 06's had ONE converter but were CA bikes
George, So your 06 California 1200 had one catalyst unlike the 06 49 state 1200s which had none while the 06 49 state 883s had one? Could you post your California info on the Cat Con thread that Bone mentioned here? Thanks!
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
The removal of Zink and other cat harming aditives is the reason behind the Factory telling you to use Diesel engine oil if car oil is to be used in an emergency.
That's when it comes to dino oil anyway, if you use synt then don't worry, they do not need those aditives.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Not true - well, not true for diesel and motorcycle oils, as the synthetics still use just as high levels of ZDDP.
Some old data - but not so old that it was prior to the latest API standards and though some of this may have changed, the patterns of levels are likely the same/similar today.
Anyway, you'll see plenty of snythetics that use high levels of ZDDP (based on viscosity - which is basically how the car oils and diesel/motorcycle oils were separated by practical application).
Name Vis P (ppm) Zn (ppm) B (ppm) Detergents (ppm) API Date Type Source
Amerilube 10w50 1254 1115 3001 SL 04/07 SYN Blackstone
Amsoil AFL Euro 5w40 701 804 50 1452 SL 11/06 SYN Staveley
Amsoil HDEO 5w40 794 1081 2276 CJ-4 11/06 SYN Staveley
Amsoil Series 2000 Racing 20w50 1014 1123 12 3209 SM 02/07 SYN Blackstone
Amsoil V-Twin/MC 20w50 1193 1281 3564 SJ 11/05 SYN Staveley
Amsoil XL-7500 5w20 434 532 165 1601 SL 08/06 SEMI Blackstone
Amsoil XL-7500 5w20 334 1096 209 3061 SL 06/06 SEMI Staveley
Castrol Act Evo 20w50 765 1126 1724 SG 05/06 DINO Staveley
Castrol GPS 4STK MC2 20w50 767 1133 1544 SG 05/06 SYN Staveley
Castrol GTX 20w50 1157 1422 1848 SM 11/05 DINO Staveley
Castrol GTX High Mile 20w50 1248 1382 1848 SM 06/06 DINO Staveley
Castrol Syntec 5w40 786 918 1979 SL 09/06 SYN Blackstone
Castrol Syntec 5w50 921 914 58 2628 SM 11/05 SYN Staveley
Castrol Syntec Blend 20w50 937 916 1197 SM 03/07 SEMI Staveley
Castrol Tection Extra 15w40 965 1094 46 2461 CI-4 3/07 DINO Blackstone
Castrol TWS 10w60 425 1294 111 2383 SJ 06/06 SYN Staveley
Chevron Delo 400 15w40 1191 1622 3668 CI-4 06/06 DINO Staveley
Delvac 1 5w40 1390 1803 76 2583 CI-4 11/05 SYN Staveley
Delvac 1300 Super 15w40 1380 1702 78 2388 CI-4 11/05 DINO Staveley
Elf 505.01 VW 5w40 584 1092 2691 SL 05/06 SYN Staveley
Exxon Av Break-in oil 20w50 1 4 23 N/A 11/05 DINO Staveley
Exxon Av Oil 20w50 702 32 33 N/A 11/05 SEMI Staveley
Exxon Superflow 20w50 717 848 96 2650 SM 06/06 DINO Staveley
Ford Motorcraft 5w20 545 848 298 2005 SM 01/07 SEMI Staveley
Harley Davidson Syn3 20w50 1081 1182 264 1482 SG 11/05 SYN Staveley
Havoline 20w50 425 494 87 1049 SM 03/07 DINO Blackstone
Joe Gibbs Racing XP5 20w50 920 1231 504 SG 04/07 SEMI Blackstone
Kendal GT (Vintage) 20W50 1229 1415 2408 SE 11/05 DINO Blackstone
Kendall GT 20w50 904 1233 2885 SM 06/06 DINO Staveley
Kendall GT 10w30 582 872 278 1416 SM 11/05 SEMI Staveley
Kendall GT 10w40 598 897 282 1565 SM 11/05 SEMI Staveley
Lucas High Perf. Motor Oil 20w50 386 460 214 1079 SM 02/07 SYN Blackstone
Mobil 1 0w40 761 876 167 2630 SM 03/07 SYN Blackstone
Mobil 1 0w40 796 907 178 2650 SM 03/07 SYN Blackstone
Mobil 1 0w40 808 976 185 3256 SL 04/03 SYN Blackstone
Mobil 1 0w40 706 834 148 2246 SM 02/05 SYN Blackstone
Mobil 1 15w50 952 1030 41 2175 SM 03/07 SYN Staveley
Mobil 1 EP 15w50 1193 1376 228 2970 SL 04/07 SYN Blackstone
Mobil 1 EP 15w50 1062 1279 79 2485 SM 04/07 SYN Blackstone
Mobil 1 EP 15w50 906 1024 72 2071 SM 01/06 SYN Blackstone
Mobil 1 EP 15w50 1315 1428 226 2593 SL 11/05 SYN Staveley
Mobil 1 mx4t 10w40 1277 1460 188 2025 SG 03/07 SYN Blackstone
Mobil 1 mx4t 10w40 1411 1623 188 2248 SG 04/07 SYN Blackstone
Mobil 1 R 0w30 1399 1536 178 3051 SG 02/04 SYN Blackstone
Mobil 1 Super Syn 15w50 1343 1390 205 2601 SL 11/05 SYN Staveley
Mobil 1 Truck & SUV 5w40 1034 1247 51 2826 CI-4 04/07 SYN Blackstone
Mobil 1 V Twin 20w50 1329 1949 204 2130 SG 11/05 SYN Staveley
Mobil 5k Clean 10w40 660 1028 2895 SM 06/06 DINO Staveley
Mobil High Mile 10w40 527 1021 2844 SM 06/06 DINO Staveley
Motul 300V Competition 5w40 1317 1409 19 3273 SH 04/05 SYN Blackstone
Motul 300V Competition 15w50 1139 1130 20 2410 SH 05/05 SYN Blackstone
Motul 505.01 VW 5w40 973 1226 2830 SL 05/06 SYN Staveley
Motul Competition 15w50 1148 1327 11 2723 SH 05/06 SYN Staveley
Motul Tekma Mega 15w40 1220 1737 145 3469 CI-4 05/06 DINO Staveley
Mystik 15w40 1130 1224 3104 CI-4 03/07 DINO Staveley
Mystik 10w50 700 799 2003 CI-4 03/07 SEMI Blackstone
Pennzoil 20w50 501 800 223 2062 SM 01/07 DINO Staveley
Quaker State Q Full Syn 5w50 923 908 1917 SM 11/05 SYN Staveley
Redline 15w50 924 1004 27 2287 SM 02/07 SYN Blackstone
Redline 10w40 1440 1872 3039 SL 11/05 SYN Staveley
Rotella 15w40 843 946 26 1881 CJ-4 03/07 DINO Blackstone
Rotella 15w40 996 1130 32 2054 CJ-4 04/07 DINO Staveley
Rotella 15w40 1278 1555 2946 CI-4 11/05 DINO Staveley
Rotella 5w40 1397 1552 2921 CI-4 11/05 SYN Staveley
Royal Purple 20w50 668 763 2034 SJ 02/07 SYN Blackstone
Royal Purple 20w50 1290 1337 3295 SJ 11/05 SYN Staveley
Royal Purple Max Cycle 10w40 4085 1222 2599 SJ 07/05 SYN Blackstone
Royal Purple Max Cycle 20w50 3179 1030 2142 SJ 04/07 SYN Blackstone
Royal Purple Max Cycle 20w50 3907 1458 2478 SJ 11/05 SYN Staveley
Royal Purple Racing 51 20w50 1285 1417 2639 SJ 11/05 SYN Staveley
Royal Purple XPR 10w40 1034 1741 2709 SJ 12/06 SYN Blackstone
Schaeffer 7000 Supreme 20w50 1249 1626 2451 SL 06/06 SEMI Staveley
Schaeffer 9000 Supreme 5w40 1113 1315 10 3126 SL 07/05 SYN Blackstone
Torco SR-1 20w50 363 412 759 SG 03/07 SYN Blackstone
Torco SR-5 20w50 1072 830 10 1481 SG 02/07 SYN Blackstone
Torco T-4SR 20w50 1059 969 1293 SG 05/06 SYN Staveley
Torco TR-1 20w50 670 571 958 SG 03/07 SYN Blackstone
Torco V Series ST 20w50 1030 1286 2231 SG 05/06 SEMI Staveley
Valvoline All Fleet Plus 15w40 1110 1232 3559 CI-4 10/06 DINO Staveley
Valvoline Durablend 20w50 566 732 13 2606 SM 06/06 SEMI Staveley
Valvoline Max Life 20w50 691 879 17 2170 SM 11/05 DINO Staveley
Valvoline Prem. Blue 15w40 1314 1838 158 4329 CI-4 06/06 DINO Staveley
Valvoline Synpower 20w50 605 689 1786 SM 03/07 SYN Blackstone
Valvoline VR1 20w50 1085 1293 17 2242 SL 11/05 DINO Staveley
Valvoline VR-1 NSL 20w50 835 976 10 819 SL 03/07 DINO Blackstone
Valvoline VR-1 NSL 20w50 842 962 11 838 SL 03/07 SYN Blackstone
Bardahl No Leak/Smoke 53 4 0 11/05 O/A Staveley
Boron Motor Silk 116 0 05/06 O/A Staveley
CD-2 Maxx Detergent 1 7 2416 11/05 O/A Staveley
CMW Racing Concentrate 2292 1147 358 06/06 O/A Staveley
GM Cam Lifter Prelube 5710 5876 29004 01/07 O/A Blackstone
GM EOS Assembly Lube 5762 6221 8265 01/07 O/A Blackstone
Lucas Oil Stabilizer 36 13 0 01/07 O/A Staveley
Power Service Oil Extender 3567 4945 6394 11/05 O/A Staveley
Schaeffer Micron Moly 110 5 0 08/06 O/A Staveley
STP Blue 1704 2436 88 11/05 O/A Staveley
STP Red 2115 3932 901 11/05 O/A Staveley
Valvoline Max Life Protect 537 768 22 3871 11/05 O/A Staveley
Valvoline Synpower 356 551 650 11/05 O/A Staveley
Here are the running averages for all the oils tested thusfar:
API P (ppm) Zn (ppm) B (ppm) Mo (ppm) Ca (ppm) Mg (ppm) Na (ppm) Total Detergents
SE-SJ 1301 1280 151 357 1936 293 214 2443
CI-4 1150 1374 83 80 2642 199 2840
SL 994 1182 133 273 2347 109 22 2479
CJ-4 819 1014 26 2075 7 2082
SM 770 939 127 122 2135 13 139 2287
norseXL's Avatar
I just kind of remembered a oil article from Donny Peterson and there the analysis showed less metals but huge amounts of Molybden in Synt.
Can't find the article anymore tho.
Old 22nd February 2013
Zortag's Avatar
Zortag Zortag is offline
Sportster/Buell Model: Iron
Zortag is an unknown quantity at this point
Boy am I sorry I asked
now, at the risk of causing more confusion, I thought that the big difference between automotive and motorcycle oil were the additives like moly etc... that could cause clutch problems in shared systems, but since the sportster has seperate engine/transmission oil it was ok(ish, not trying to start a debate, just understand) to use for the engine, but not the tranny.
Also, as an addendum to this whole thread, I was re-reading, and it is the PENN GRADE 1 that is not recommended for cats, not their regular oil...so ya, sorry about that
Old 12th January 2014
rejeanprimeau's Avatar
When I gronk mod my cat equip exhaust; international 883 R model sold im Canada, I cut the weld's tacks at the body of the front muffler. I immerge the muffler in water so as not to blue the chrome. I use s dremel equip with a cutting disk and made sure the inner will slip out. I did cut the cat part, then add a piece of 1 1/4 pipe to the inner baffle so it sit as the one without the cat did. I drill the hole to my liking. When the power start to drop i close some holes an then at max power reweld both baffle in. 10 dyno pulls was use so go to a friend with one. The back muffler was easy to reweld= regular gronk mod. The front one was immerse in water as to cool the 3 weld spots. You can barely see it so make sure to tack it were it will show the less or paint black and don't worry.
Old 20th February 2014
Jimmy_Hoffa's Avatar
Jimmy_Hoffa Jimmy_Hoffa is offline
Jimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to all
I've seen the bradpenn warning also, then I saw something funny; STP oil additive now says on the bottle that it has the zink additives, but STP does not say not to use it in cat equiped vehicles. I've been running 15-40 in my gas engines (cat equipped) for about a decade now. Near 300,000 miles on one without any cat problems.
IMO, you'd have to be burning quite a bit of oil to be getting much zink in your cat. Better safe than sorry though I guess. My dad had a cat fire years ago, it was no fun. Class Delta fire, couldn't put it out with water or fire exstinguishers.
Old 9th April 2020
glbsportster's Avatar
glbsportster glbsportster is offline
Sportster/Buell Model: 1200 C
glbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond reputeglbsportster has a reputation beyond repute
Just went out and checked both the head pipes and mufflers on my 2009 1200C and did not see anything on them about containing a catalytic converter. Both mufflers did say they met the noise emission standards.
Old 9th April 2020
Folkie Folkie is offline
Your mufflers don't have cats. US Sportsters didn't have cats until 2014.
