Last Post: Reverend G
0 Mid West Meet & Greet
Last Post: Bow only
Last Post: 72 Ironhead XLH
0 900cc Pistons
Last Post: mickey t
Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: RDHenley
0 No oil flow
Last Post: MkC
Last Post: SwissXL
2 Your daily tunes...
Last Post: RDHenley
Last Post: batchman
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
0 Getting Hammered
Last Post: Bryan83taco
0 Willi is back!!!!
Last Post: Oldmxdog61u
0 Problem on a trip
Last Post: 1968xlch900
  #111
Old 9th April 2020
Blackbenny Blackbenny is offline
Sportster/Buell Model: Iron 883/1250
Sportster/Buell Model #2: 48
Sportster/Buell Year #2: 2016
Blackbenny is an unknown quantity at this point
Great write up! I just had to rebuild
My master on a 15. I’m still trying to get all the air out. It’s driving me nuts. The kit I got the cups were way smaller then the ones I pulled out. Do they expand or something? I’ve been trying to bleed for so long I’m wondering if something is wrong. Reverse bled.
Old 9th April 2020
Redbeard2's Avatar
Redbeard2 Redbeard2 is offline
Sportster/Buell Model: M2 Cyclone
Other Motorcycle Model: Suzuki GSF1200S Bandit
Other Motorcycle Year: 2002
Redbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud of
Default Send Pix
You need to post some pix. Most this thread is on the 04-12 [I think I got the years correct] underslung rear master cylinder on the Harley rubbermount Sportsters and problems associated with them. Your rear brake system is is entirely different and you should have posted it on a new thread I think. Harley went back to a side mounted master cylinder in 2013 I'm pretty sure because the 04-12 master cylinders had a lot of problems. It's a bit Rube Goldberg for one thing and has too many parts!
Old 9th April 2020
rejeanprimeau's Avatar
Yes
Open up the oil tank and press the pedal, if you see a geyser of oil shooting up, yes you have the rubber cup tears problem.
Old 9th April 2020
The boot and one cup was thrashed. I rebuilt it. The only thing was the 2 cups were smaller. Same shape tho. I don’t see how the originals even got stuffed in there. It was a harley kit. I checked twice before I installed. I just can’t get this spongy feel out
Old 9th April 2020
https://imgur.com/DW0Z6Gy
Old 9th April 2020
wedge's Avatar
wedge wedge is offline
The rear on my 05's is a bear to bleed. I use a mity-vac. Attach it at the bleeder, put grease around bleeder threads to reduce air intake, make sure you are keeping an eye on the MC reservoir to keep it from going dry. With a canister in the mity-vac line, you add vacuum to the bleeder valve, crack it open (but not too far) and watch the clear line to see when the bubbles and watch for them to stop, it takes longer than you may think and you will go through some fluid.
Note: you will get air pulling past the caliper seals, so there will be a stream of very tiny bubbles after you get the real problem ones out. (you can reduce those by closing the bleeder a bit). Stop there by closing the bleeder valve. Top off the MC, and you will be good to go.
Old 9th April 2020
I’ve literally got the caliper hanging with a valve on it and it’s still spongy. 0 air now. I’m at a loss. Wonder if there is something wrong with the rebuild.
Old 10th April 2020
vferdman's Avatar
vferdman vferdman is offline
Sportster/Buell Model: XL883
vferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the roughvferdman is a jewel in the rough
I bled mine the old fashioned way after failing to do so with vacuum. I just pressed the brake pedal, opened the bleeding screw, let the bubbles out, closed the bleeder, repeat. After a while of that I got a nice stiff action on the pedal. It's still that way, years after my original post. The problem with the setup is there is a bunch of line above the bleeder and the air settles in the highest part of the system. Maybe try raising the caliper above that master cylinder and try again. All I know is that mine did not want to bleed the air out using vacuum, but the old fashioned way worked like a charm.
Vladimir
'04 tax-paid XL883
Pioneer Valley, MA
Old 10th April 2020
wedge's Avatar
You are correct in my opinion. The problem does seem to be that hump in the line.
I have to wonder about the difference in size that Blackbenny mentioned.
At this point, I would take the original parts to the dealer and compare them to the kit, and make sure it is the correct kit for the MC on that bike. This can be done without even pulling it apart as long as you still have the take off parts. Usually it's the older ones that look a tad smaller because the lip gets worn off and more conformed to the bore that is smaller than the spread of the new cup lips.
