0 SE.536 cams, who has a set sitting around
Last Post: chilly
0 Big bore Stroker problem
Last Post: XL1275
0 XLCH chainguard
Last Post: ricusa
0 One More Ohio Meet & Eat?
0 New oil tank
0 Done for now (no really)
0 It's Glamazon's Birthday!
0 newbie
0 Oil leaking
Last Post: Zari
0 Gear Spacing Question
0 FAF Sporties
Last Post: drgonzo21
0 Any wealthy forum members?
Last Post: 1200CustomHD
Last Post: Full-Bore12
0 30 tooth pulley? For ‘04-06
Last Post: Mike1nw
0 Rare As Hens Teeth? (Stock Parts Secondhand)
Last Post: Mike1nw
0 Disassemble tranny HELP
Last Post: Mike1nw
0 Reassemble engine
Last Post: Mike1nw
0 1991 Manifold Bolt Trivia (?)
Last Post: 45Brit
springer on sportsters
FiftySixer's Avatar
FiftySixer FiftySixer is offline
Hollywood Pixelmagician
Sportster/Buell Model: Sportster XL883C / 1250
Sportster/Buell Model #2: 2001 XL 883C/ 1250 Hammer
FiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud ofFiftySixer has much to be proud of
Default Moto Iron Springer on a Stock 2001 Sportster
Moto Iron on 20001 Sportster:
Fellow Forum Members
Question.
(1). Will the Moto Iron Springer front end install onto the 2001 Sportster without further modification?
(2). Will the fork lock tab on the frame need to be cut?
(3). Will there be any modifications necessary to the fuel tank in the stock position.
(4). I'm running 6" risers with the 1" lane Splitter bars. - What length of stainless steel braided cable do I need?
Any help with theses questions are greatly appreciated,
I Do Custom One Of A Kind Graphic Designs & Websites for bike parts! Check Out My Image Album
Black 2001 XL883 Custom, Hammer Performance 2004+ Big Fin 1250 kit with Flat top pistons, 2004+ XL 1200 Heads new built by Hammer,
Hammer 570 Cams, 42mm Mikuni HRS Easy kit, Twin Tech Single fire coil, Twin Tech Ignition, Hammer billet manifold,
S&S Roller Rockers, New Push Rods, Telescopic push rod tubes, Hammer 3" Air Cleaner & Filter,
Pingle High Flow petcock, 04+ oil pump & bronze gear/Chrome White Brothers 2 into 1.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Only thing I could find on the forum
http://xlforum.net/forums/showthread.php?t=679680
Won't answer your detailed questions though.
On my 2001 883. I had to grind the stops on my lower triple tree for the single disc wide glide front end. Steering lock is not used. I Pm'd you some offsite links with info. Like I said. TC Bros may have some answers since they sell the specific front end you started this thread with ..
Traveled to
OCRyder OCRyder is offline
Sportster/Buell Model: 883
OCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to behold
It will fit but it will hit the tank as the stops are not long enough to fit. I used clear vinyl tubing and a giant zip tie to solve the issue but it does limit the steering a bit but I've never had an issue. Here is a pic.
https://i.imgur.com/6El6emQ.jpg
Zoom in on the neck and you'll see the tubing and how close the top of the springer is to the tank.
FiftySixer's Avatar
Nice looking bike.
