0 Wire question, 30A breaker to starter...
Last Post: LenC
0 Roadside Manners
Last Post: owlsplace
0 Cold Start. Then stall
Last Post: Lukidj
0 Triumph or Harley!
Last Post: heyshott 81
8 Rear Brake Light Switch Bad
Last Post: THEWILDONE
0 28 years later..
0 In tank pump and filter work
Last Post: smm1200
0 Hardtail frame conversion with 3" stretch and avoiding a chain conversion kit
Last Post: jharback
0 Pushrod cover seals
Last Post: mfc
Last Post: wymanv
2 Memory Highway
0 Hi From NJ
Last Post: Calcustom
0 Cost of ejikation
Last Post: Skuzeee
0 Best way to 883->1200cc ?
0 Clutch issues
0 Primary will not seal
0 Tillotson Welch Plugs
Last Post: Coz
14 HD ad for Dirt?
Last Post: gusm2
0 Bearing questions
0 Turn signals and switch required 1972 xlch
oakies, Gunhappy2 (61), SamIam (55), biggdann (49), boyer911 (49), danii (42), PVD24 (40)
Old 31st May 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Mikuni KHS-025 jet kit. Sells for anywhere between $85ish and $125ish from what I can see.
Includes 150 through 170 main jets (2 each) 22.5 through 35 pilot jets (2 each) -96, -97 and -98 needles (1 each) and 2 #60 a/p nozzles, needle clip, all necessary washers, special jet box.
The way I see it, between what I paid for it and the HSR42-11, I pretty much got the jet kit for free.
HSR42 25 pilot 1 1/2 turns 97 needle 2nd groove 170 main
Old 1st June 2019
60Gunner's Avatar
Chief of Security
Talk about fast shipping. Got the carb today. 1 day shipping. In a sealed package from Mikuni just like he said. He didn't get confirmation on payment til too late to ship for the dealer kit but it's going out today by speedee delivery instead of priority mail so I may get it yet today. Its only 50 miles away.
Old 2nd June 2019
60Gunner's Avatar
Chief of Security
Reading over the parts list and tuning instructions it looks like the 42-11 kit comes with a 25 pilot, 165 main , 97 needle with clip in the middle and #70 AP. I MIGHT need a 27.5 pilot and a 167.5 main out of that dealer kit. I'm going to pass the good price on that kit to someone that tunes the 42, 45, and 48s or eBay it.
Old 2nd June 2019
60Gunner's Avatar
Chief of Security
Ok. That baby is a snug fit but she's on. It comes with a 160 main installed and a 155,165 in the box. Put the 165 in. It has a 25 pilot, 97 needle in the 3rd clip. Should be pretty close. Oh and the accelerator pump nozzle is a 70.
I might not even need any jets out of the kit coming tomorrow.
Came with thechoke spring and plunger to swap out on the stock cable too and the long idle adjustment that hangs there. Almost too long. There is a short version.
Old 3rd June 2019
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Did you clearance the cylinder fins for fitment?
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 3rd June 2019
60Gunner's Avatar
Chief of Security
It fits without any clearancing but just barely. But after looking at it last night I see I can't drop the bowl. The rear screws sit right above the very corners of the top fins of the cylinders. So I will have to do a little clearancing if I ever want to be able to drop the bowl without pulling the carb. Otherwise, it goes on but theres no rocking it up and down or side to side very much to get it in the intake seal which is a nice tight fit too. But it went in and my bracket pulls it in nice and tight with a little lube on the seal. Definately no air leaks.
Fortunately I think I'm good to go with the stock 25 pilot and 97 needle with the clip in the 3rd position. The #70 AP nozzle is good too. I can fine tune that if need be. All I changed was the 160 main to a 165 but havent really had it full throttle yet. The main can be changed easy tho with just removing the plug so I doubt I'll mess with any clearancing just to be able drop the bowl.
Old 3rd June 2019
60Gunner's Avatar
Chief of Security
There also seems to be different versions of this carb/kit. This one, the 42-10/42-11 directly from mikuni comes with a 25 pilot. An SE version apparently comes with a 20. Also this one cones with the #70 accelerator pump nozzle. The SE version a 60. They both have a 97 needle but the SE version comes with the clip one notch leaner.
This one is setup near perfect for my 1250 build. I did change the main jet from a 160 to a 165. I have tuned the main yet as I haven't quite cranked the throttle wide open.
It says for 94 to present sportsters and all carbed 1200 buells.
