0 Roadside Manners
Last Post: owlsplace
0 Cold Start. Then stall
Last Post: Lukidj
0 Triumph or Harley!
Last Post: heyshott 81
8 Rear Brake Light Switch Bad
Last Post: THEWILDONE
0 28 years later..
0 In tank pump and filter work
Last Post: smm1200
0 Hardtail frame conversion with 3" stretch and avoiding a chain conversion kit
Last Post: jharback
0 Pushrod cover seals
Last Post: mfc
Last Post: wymanv
2 Memory Highway
0 Hi From NJ
Last Post: Calcustom
0 Cost of ejikation
Last Post: Skuzeee
0 Best way to 883->1200cc ?
0 Clutch issues
0 Primary will not seal
0 Tillotson Welch Plugs
Last Post: Coz
14 HD ad for Dirt?
Last Post: gusm2
0 Bearing questions
0 Turn signals and switch required 1972 xlch
oakies, Gunhappy2 (61), SamIam (55), biggdann (49), boyer911 (49), danii (42), PVD24 (40)
fuelpak3, short pipes, sportster 48, tuner
Old 4th June 2019
I AM GRUNT's Avatar
I AM GRUNT I AM GRUNT is offline
Sportster/Buell Model: Sportster 48
Sportster/Buell Year: 2019
I AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to behold
Default Tuning after new pipes
Hey guys, so I bought new LAF Porker short pipes for my 2019 Sportster 48. I know I should tune it to get optimal performance out of it. However, the Fuelpak software doesn’t have a selection for the LAF Porker pipes. Anyone have any idea as to what pipes would be similar to them ? this is what they look like.
Sincerely, The Grunt | 2019 Sportster XL1200X
Last edited by I AM GRUNT; 4th June 2019 at 18:48.. Reason: Clicked save accidentally
Old 5th June 2019
b0fh's Avatar
b0fh b0fh is online now
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
short shots
Old 5th June 2019
I AM GRUNT's Avatar
Originally Posted by b0fh View Post
short shots
Really ? Can't be man. Short Shots are suuuupperrrr long compared to these. Thanks for the reply though !
Old 5th June 2019
Then call V&H and ask what mapping they have you can use "to get optimal performance" out of your LAF Porkers.
Old 5th June 2019
I AM GRUNT's Avatar
Are you being rude ? And if you are, it’s than* not then. But good idea, I’ll definitely check into that. Thank you
Old 5th June 2019
b0fh's Avatar
those pipes will never work right, but short shots will probably be the closest match in te database of tunes. the fp3 can ‘auto tune’ itself from that base line.
Old 5th June 2019
I AM GRUNT's Avatar
Yeah which sucks. But I got a reply from a guy at Revzilla who said the same thing about the auto tune feature. And I believe the Bassani Radial Sweepers are the closest comparison. AGAIN I really appreciate your insight
