0 Wire question, 30A breaker to starter...
Last Post: LenC
0 Roadside Manners
Last Post: owlsplace
0 Cold Start. Then stall
Last Post: Lukidj
0 Triumph or Harley!
Last Post: heyshott 81
8 Rear Brake Light Switch Bad
Last Post: THEWILDONE
0 28 years later..
0 In tank pump and filter work
Last Post: smm1200
0 Hardtail frame conversion with 3" stretch and avoiding a chain conversion kit
Last Post: jharback
0 Pushrod cover seals
Last Post: mfc
Last Post: wymanv
2 Memory Highway
0 Hi From NJ
Last Post: Calcustom
0 Cost of ejikation
Last Post: Skuzeee
0 Best way to 883->1200cc ?
0 Clutch issues
0 Primary will not seal
0 Tillotson Welch Plugs
Last Post: Coz
14 HD ad for Dirt?
Last Post: gusm2
0 Bearing questions
0 Turn signals and switch required 1972 xlch
oakies, Gunhappy2 (61), SamIam (55), biggdann (49), boyer911 (49), danii (42), PVD24 (40)
View Poll Results: HRS 42 AP Nozzle: Which One?
60 2 100.00%
70 0 0%
Voters: 2. You may not vote on this poll
Old 8th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I delayed it a lot. It runs great. Just seems like once it's warmed up and I blip the throttle while idling it's not as smooth as it should be. Seems better with the 27.5 and 1 3/4 turns out and the pump delayed.
Otherwise it's a screamer.
Wondering maybe the ckp?
HSR42 25 pilot 1 1/2 turns 97 needle 2nd groove 170 main
Old 8th June 2019
How is it cold? When it's better cold you're too rich. If it gets worse as your engine temp rises you're too rich.
Is your mixture screw adjusted for best idle? No cheating allowed here. If it's not it throws everything else off.
If you open the idle mixture screw (another) 1/2 turn is it better or worse?
What is "ckp"?
Old 8th June 2019
60Gunner's Avatar
Chief of Security
Ok took it out for a nice nice hiway cruise and I think I got it. Need to bring squirter back on a little sooner tho or maybe raise my needle.
27.5 1 3/4 turns 97 needle middle groove 170 main.
Nice idle.
https://youtu.be/bHWW7WEZuMo
Old 8th June 2019
60Gunner's Avatar
Chief of Security
What is "ckp"?
Crank position sensor.
Another 1/2 turn either way is worse.
I don't know how some of you are running a 17.5 pilot. Mine popped like crazy and even died a couple times with a 20 at 1 turn out. You must be up there with the airplanes at 10,000'!
CycleShacks should be here tomorrow. Wish I could afford to play on a dyno. I think the straightshots with the HP Plus baffles would smoke it pretty good. Especially upstairs. But I think the CycleShacks will pull harder in the basement and 1st floor.
Old 8th June 2019
60Gunner's Avatar
Chief of Security
I might add this was right at dusk, low 70s, humidity around 68% at 630' ABS. Plenty of air! I'm sure it's a little on the rich side tho. Has to be to get an idle like that with the lower compression of a 1250 flat top with the 570s. Doesn't pull the fuel as well as a motor with 200+ cranking compression. I'll most likely go back to the 25 pilot. I think with the 25 I can fine tune the idle with the screw for changes in temp/humidity. I'll tune the pump to come on a little sooner than it is now too tho. It's quite late now. MAYBE raise the needle tho. I'm heavy on the throttle and it feels a little lean at first rolling on it hard.
Going to experiment with the timing now.
