0 Wire question, 30A breaker to starter...
Last Post: LenC
0 Roadside Manners
Last Post: owlsplace
0 Cold Start. Then stall
Last Post: Lukidj
0 Triumph or Harley!
Last Post: heyshott 81
8 Rear Brake Light Switch Bad
Last Post: THEWILDONE
0 28 years later..
0 In tank pump and filter work
Last Post: smm1200
0 Hardtail frame conversion with 3" stretch and avoiding a chain conversion kit
Last Post: jharback
0 Pushrod cover seals
Last Post: mfc
Last Post: wymanv
2 Memory Highway
0 Hi From NJ
Last Post: Calcustom
0 Cost of ejikation
Last Post: Skuzeee
0 Best way to 883->1200cc ?
0 Clutch issues
0 Primary will not seal
0 Tillotson Welch Plugs
Last Post: Coz
14 HD ad for Dirt?
Last Post: gusm2
0 Bearing questions
0 Turn signals and switch required 1972 xlch
oakies, Gunhappy2 (61), SamIam (55), biggdann (49), boyer911 (49), danii (42), PVD24 (40)
carb, jetting, spark plug, super e
T_worth T_worth is offline
Sportster/Buell Model: Xlh 1200
Sportster/Buell Year: 96
T_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura about
Default NGK spark plug heat range question
I purchased a 97 xl1200 sport. It has an S&S Super E with a Thunderjet installed and Paugcho Upsweep exhaust. When I got it, it was running a little rich so I decided to try and rejet it.
It originally was Interm: 28, Main: 68. I started with changing the interm first. I went down ONE SIZE to .0265. spark plug shows engine running lean. Then I kept the interm .0265 jet, and then went up ONE size on the main to 70. Ran it around, spark plug shows lean still.
I was getting confused, so I went back to the original Interm: 28, Main 68 just to start from scratch with better knowledge than I had started with. It idles steady and is smooth through the RPMs. No backfire. Plugs show that its now a little too rich. Isn't powder carbon, just black. The electrode was a lighter black and no carbon on it.
I'm using NGK DCPR7E (#3932) spark plug, with a gap at .040. s&s states open drag pipes will make tuning carb more difficult. Well....it is. I'm coming to the conclusion that with my pipes, I'm just gonna have live with running slightly rich.
Any thoughts or tips? Could a hotter spark plug balance out the fuel mixture???
ReddTigger's Avatar
with open pipes you have to tune to one setting and thats that.. you're not going to be able to balance out the bike properly because drag pipes are for wide open throttle the whole 1/4 miles.. Not for torque around a turn.. you can try fixes like lollipops and cones and other snake oil.. but for proper turning you're going to need a proper pipe..
are you running stock cams as well ?
you can try and see if a different plug with the bike will do anything different, but i think you're just chasing your own tail at that point.
so to answer your question, i dont think you're going to benefit from a plug change.
States I've Ridden in
71.3 hp 70.8 tq
What do you mean "one setting"?
I'm not sure, I haven't checked those out yet. I don't think the PO changed much of the internals of the bike.
Correct me if I am wrong with this thinking. But, would a hotter plug thats 1 heat range hotter compensate for the extra fuel (rich) and make the engine a bit leaner?
Air-Cooled Forever
You only want to run a hotter plug if they are fouling from a "too rich" condition. If you run a hotter plug to correct the "rich" condition, you take the chance of detonation and pre-ignition. It will not, necessarily, "lean" it out. So, if they are not fouling, you should be good. If you want to lean it out, you'll need to re-jet and put some backpressure in the pipes.
ReddTigger's Avatar
most carbs have several settings that can be tuned to...
idle, part throttle, and full throttle.
depending on which pipe you have and how it reacts at different settings will determine how one sets up a carb..
with straight pipes, your only option is a wide open setup.. t hat's the one setting I was referring to.
Old 6 Days Ago
perhaps the thunderjet needs tweaking.
the two circuit carb is known for the issues you have.
Old 6 Days Ago
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
I run 8s in my Hammer hotrod and Hammer recommends 9s.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Old 6 Days Ago
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I run the 9s in hot summer fl.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 6 Days Ago
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I ended going back to 7s in my 1250/570 build.
HSR42 25 pilot 1 1/2 turns 97 needle 2nd groove 170 main
