Last Post: soundnav
0 Early Sportster Shock Absorber Disassembly
Last Post: soundnav
0 Rear wheel alignment
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 Sprortster Softail 1200 with Edelbrock NOS
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
Default Backfire
Getting a loud backfire on startup about 50% of the time.
Bike cold or hot, with or without throttle.
This has been for a while now
Otherwise runs pretty good.
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertramp 2/2
2003 - Original Nosecone Ignition Module?
Maybe a loose connection somewhere?
Then check your coil connections...
Steve9's Avatar
IXL2,
Bike in my sig. dyna tech nosecone ignition.
And the motor doesn't miss otherwise
Would timing cause this?
davesz1r's Avatar
davesz1r davesz1r is offline
Sportster/Buell Model: xlh 883 hugger
Other Motorcycle Model: kz1000 z1r
Other Motorcycle Year: 1978
davesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to behold
Might be timing. But mine does it about the same. I rode rocketmangbs cannibal queen last weekend and it did it too. Both bikes are tuned well and have no known electrical problems. Me thinks it's just raw fuel lighting off I
In the pipe when lost spark fires the cylinder that is on the exhaust stroke. Maybe someone smarter than me will chime in.
1275 cc 10.54:1 cr se heads .560 cams hsr42 dyna 2000p patriot defender 11.63@ 115 1/4
harley506d's Avatar
Sportster/Buell Model: 1200c
And don't blip the throttle when you shut down!
Steve9's Avatar
Yeh, she starts immediately-first revolution of the motor 'most ever time. Very eager
lespaul6's Avatar
lespaul6 lespaul6 is offline
Sportster/Buell Model #2: 2002 XL 1200C
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL1200C
lespaul6 has disabled reputation
I used to do this by priming with a few quick squirts of the throttle before starting...it was fun in the morning for the neighbors... my bike was running a little lean and I adjusted the IMS- never could get the backfire again. For me it had nothing to do with timing.
Steve9's Avatar
Thinking might be waste spark. I thought it was single-fire, might be wrong
