0 Rear wheel alignment
0 Anyone know normal operating temp?
0 Ignition advice
Last Post: Rhode Warrior
0 Sprortster Softail 1200 with Edelbrock NOS
0 CV carb running way rich!
0 I was at the gym yesterday
0 Koso hd-01-04 2014+
8 Crankshaft Failure
0 wavers
0 Need help with turn signal and tail light connections
Last Post: keys79
Last Post: Sasnak75
5 Harley T-Shirts
Last Post: Kbetts
0 HELP Identify These Headers Please
Last Post: FiftySixer
Last Post: Tipofthelake
Last Post: PetesPonies
0 Remember these?
0 Sissy bar with HD quick release bracket
0 Basket case
Last Post: bill smith
0 Cv carb jetting
0 Buell Blast headlight compatibility
Last Post: apotheon
0 Down on oil
Last Post: Billy1200
1911Bronco, Blackbird (82), thai808b (65), Nathan71 (51), lucky-13 (49), Barndog (47), discobanjo (43), albana (41), pat5150 (36)
stavenironhead's Avatar
stavenironhead stavenironhead is offline
stavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the roughstavenironhead is a jewel in the rough
Default The Dreaded Base Gasket Leak
Hello all! I haven't been on the forums in awhile. I sold my 1977 Ironhead last year and been riding an 84' Shovelhead Low Rider since.
Trying to help out a neighbor who just acquired a 97' Sportster 1200 for his daughter. When he brought it home the rear base gasket was puking oil.
I helped him replace the base gasket. Followed the "torque wrench method" found here http://www.nightrider.com/biketech/h...rquevalues.htm
We cleaned the gasket surfaces well.
Still leaking but not puking like before.
Tear it back apart for another new gasket or are there any tips here? I made sure to let him know to WARM up these Evos good before thrashing on it.
davesz1r's Avatar
davesz1r davesz1r is offline
Sportster/Buell Model: xlh 883 hugger
Other Motorcycle Model: kz1000 z1r
Other Motorcycle Year: 1978
davesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to behold
Factory hd gaskets or cometic mls?
1275 cc 10.54:1 cr se heads .560 cams hsr42 dyna 2000p patriot defender 11.63@ 115 1/4
Thanks for the reply Dave.
Unfortunately I have no idea. He purchased the kit from the local Indy. It definitely is not a genuine HD gasket.
Not much help there I know. From the little research I have done the Cometic MLS is good stuff...
rocketmangb's Avatar
Base gaskets are generally one piece not MLS
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
davesz1r's Avatar
Well, cometic has specific instructions on install and torque. Using any other method guarantees problems. You should be able to see the head gasket. Factory will be paper. Cometic will be three layers of steel. You may be able to see the rivets that hold the layers together .
davesz1r's Avatar
Yes George but you have to replace the head gasket to replace the base gasket. And you know about cometic torque procedure. Also rivets interference, and not using the o rings.
All true !
