0 Sportster drag bike
Last Post: Zip1
0 Xl???
Last Post: robbie202
Last Post: ericfreeman
0 so it's officially ended
Last Post: FrankGS
0 old parts
0 '66 XLCH VM38 Conversion
0 CV Carb hesitation
Last Post: owlsplace
Last Post: Nicktater
0 Tuners
0 Morning default to odometer
0 What jets do you use?
Last Post: Thack
Last Post: Samedward
Last Post: tedcool
8 XLCH kicker giving me a major headache!
Last Post: Nightmare
View Poll Results: Have you had multiple stator failures?
Rigid- Yes 16 9.04%
Rigid- No 61 34.46%
Rubbermount- Yes 22 12.43%
Rubbermount- No 78 44.07%
Voters: 177. You may not vote on this poll
Old 25th May 2010
unfiguroutable's Avatar
unfiguroutable unfiguroutable is offline
Sportster/Buell Model: XL883L
unfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the rough
Default stator
22,250 miles
one stator...that said my bike has seemed "off" for about 8k to 10k miles. it has a history of sputtering in the cold or just when it's not full hot. i think alot of the issues I have had on my bike can be explained by a troubled charging system.
LoyaltyRB
Old 25th May 2010
serialk's Avatar
serialk serialk is offline
Sportster/Buell Model: Buell X1
Sportster/Buell Year: 99
serialk is an unknown quantity at this point
26,000km on my Buell X1 and My stator said hello to a magnet in my rotor...What a mess...putting in a new accel stator and waiting on a OEM Rotor and sprocket...what a mess. Graphite chunks everywhere, Although It could of been worse if I didnt catch it when I did...
Old 2nd July 2010
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Not sure if stator is at fault. I've gone through multiple batteries. Average battery life = 18 months. I finally made the decision to replace the stator to see if it helps. Only time will tell.
Old 2nd July 2010
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
No problems on my 04.
Although, I did have to replace one after I dropped it while changing out the primary sprocket for a 38 tooth one.
Old 2nd July 2010
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Talked to a guy the other day that had an 09.......he got his bike replaced on the Lemon Law because of stator issues!
Spent more time in the shop than on the road!
In fact....the 2nd one they put in locked up!!!!! Blew the magnets!
Stuff: YES
Old 12th July 2010
Replaced stator, voltage regulator and battery at 68,000 just before the Deals Gap run, 71,000 plus and no prcblems to speak off.
Old 12th July 2010
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
2005/1200 Custom. One battery at 30K no stator or regulator issues. One note: At about 5K I started to get over-voltage error codes (minor code so you have to look for it). Traced it to the regulator to frame ground. 2 star washers under the regulator bolts and loosing the chrome regulator cover fixed it. The manual diagram does not show a frame ground but it needs one. I also suspect that under certain conditions, the chrome cover causes the regulator to over heat.
SEMJPM
Old 23rd July 2010
miranda_barcelona miranda_barcelona is offline
Sportster/Buell Model: not yet
miranda_barcelona is an unknown quantity at this point
i love motoring , cause i canot afford a car
Old 23rd July 2010
rodhotter rodhotter is offline
rodhotter has disabled reputation
ok at 15,250 on my 06 rubber, i believe only the buell's and big twin's possibly use 3 phase units, they charge at low rpms unlike the sporty's single phase needing higher rpms to charge, i will replace single with 3 phase should mine ever die
Old 5th August 2010
brianq103's Avatar
brianq103 brianq103 is offline
Sportster/Buell Model: Ultra Limited
Sportster/Buell Year: 2016
Other Motorcycle Model: Ducati Monster 1200S
Other Motorcycle Year: 2014
brianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to allbrianq103 is a name known to all
Default Stator no; regulator yes
Engine light came on; stopped for gas; no battery power to start the bike (including bump-starting it). I had it towed to the dealer and found out it was the voltage regulator. They replaced it under the extended service plan (plus $50 deductible) as well as reimbursing me for the tow.
The bike ran without a problem and as a matter of fact the engine light went off on the highway.
