0 signature pic
Last Post: duffy
Last Post: Jaykel
0 What engine oil do you use?
0 big bore kit
0 Indian FTR Sales
Last Post: duffy
Last Post: savagegarden
0 It's stalkie's Birthday!
Last Post: priell3
0 ARCH motorcycles and more
Last Post: RDHenley
0 Un-lowering my Super Low
0 A Day in the Life...
Last Post: RDHenley
0 Hack or trike?
Last Post: RDHenley
Last Post: Kbetts
0 '59 XLH - Speedo cable route
Last Post: Guidorey
Last Post: waiteitei
buddy (66), paulrainer (66), Pedrochellie, needweknow, BunnMan (48), SolariS (43), Doc69 (39), ftptptt1234 (39), dumbmxer84 (36), nhutch40 (28), XLButler (21), Ztomasc (21)
  #41
Old 7th July 2019
Bluto Bluto is offline
Finally got the SE fully adjustable fork kit installed, was a Royal PITA thanks to the oversized washers HD supplied. (item 20 above) They were 32.5 mm OD, fork tube ID is 31mm so I machined the washers down to 30.5 mm then it all went together OK the second time.
Did a short test ride, a definite improvement and maybe will be even better with some fine tuning...all settings are per HD's recommendations currently
Old 7th July 2019
shanneba shanneba is offline
Did you use HD Type E fork oil?
When I had my forks installed the dealer had to order 2 of part number 48738-07 Spring washer.
In the instructions for the SE Fork kit that part number is listed as the fork spring.
In the 2013 Sportster parts manual 48738-07 is listed as
WASHER (2) XL1200C, XL1200C ANV, XL1200CA, XL1200CB, XL1200CP, XL1200V, XL883R
Now I know why they had to order the parts
I assume they used the 2 original washers from my stock forks and the 2 they ordered.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 8th July 2019
I did use HD Type E fork oil, looks suspiciously like ATF ;-) Thanks much for the PN, those washers are not used on my 08 XL1200R so I didn't even have two of them...but will pass that on to New Castle HD (who sold me the kit) and hopefully they will let HD know, maybe they would have a contact there that can correct the problem.
Rode another hundred miles today, forks are much improved and the kit is worth the trouble and $$$.
Old 8th July 2019
Air-Cooled Forever
I just did a fork oil change and thought Type E sure looks like ATF,too.
Old 27th July 2019
A photo showing the improvised special tools I used for kit installation.
The damper extension tool is actually a 10mm x 1.0 bicycle rear axle w/ cone nut, worked fine. Locally no one carried hardware in this size, eventually I realized I'd seen that thread somewhere before.
Used two Ohlins shock wrenches connected to two ratcheting tie down straps to compress the spring, a bit dicey but did the job.
The Jawhorse was quite handy as usual, highly recommended, use mine for all sorts of stuff.
