0 Boardtracker Project
Last Post: JonesL
0 **DK Custom- *NEW* Sportster Slip Stream Skid Plate-10% Introductory Savings**
Last Post: sleighcrane
0 Replacement clutch discs
0 79 Engine Rebuild
Last Post: Peteroo
0 Rear brake help please!!!!
Last Post: RowJimmyRow
0 Harley being delivered next week
Last Post: conv90
0 How old are you?
Last Post: RandyMac
0 Electronic jet kit
Last Post: Jordan5150
0 hey y'all
0 No spark
Last Post: Dave L
Last Post: cotton1
0 Who owns a XLH1100 Sportster?
Last Post: jayel
0 Riserless riser bars
Last Post: Dave L
0 Issue that has me stumped
Last Post: Etienne_NL
0 Soccer question
Last Post: stalkie
Last Post: paulc
Last Post: RKN
0 Thought my clutch went out or tranny, was front pulley
Last Post: Screw Loose Dan
billib (64), Scar (59), koolblue, Spor-T-1 (55), Choppershed (54), Nemo DeNovo (52), harman35 (50), Wannabee (50), crackermank (48), WORM (42)
  #141
Old 21st April 2018
Twistedrench's Avatar
Twistedrench Twistedrench is offline
Sportster/Buell Year: 4975
Sportster/Buell Model #2: ‘75 motor ‘49 frame
Twistedrench is an unknown quantity at this point
Originally Posted by KiltedIron View Post
Here are pictures. Talking to my local shop today, he said he had an over-sized trany drain plug to replace the stripped one. Sounds like a plan...
What is the bolt behind the primary drain plug the red line runs acros in the picture?
Old 21st April 2018
doodah man's Avatar
it looks like just another drain plug to me, in the right case half.
caution! do not stop on tracks.
Old 6 Days Ago
Captain Johnny Captain Johnny is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Triumph Sprint 900
Other Motorcycle Year: 1998
Captain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura aboutCaptain Johnny has a spectacular aura about
Default 69 xlch
Is the tranny drain plug between the frame rails towards the rear, right under the tranny? I removed this bolt/plug and a few ozs came out.
I pulled the stamped primary cover and a full quart came out.
After I replace the tranny drain plug and the primary cover should I just ad 24 ozs of 50wt through the fill hole in the primary cover and call it done?
I'm new to Ironheads and recently picked up a 69 XLCH that has been sitting for many years. I read this whole thread and not a lot of info on the stamped primary models. But a great thread and a great site just the same.
Old 6 Days Ago
Sportster/Buell Year: 1974
needspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud of
If you had the bike leaning on the side stand when you pulled the drain plug that would explain why only a small amount of oil came out when there was alot in the primary. It also shows why it's really unnecessary to take the plug out. They strip easily, it's better to leave it alone. Just lean the bike over and most oil will drain.
I've heard that 24 oz is the correct amount but if you do it by the manual and fill it to the level hole with the bike standing straight you'll be sure not to over fill it. Important if you're running the clutch dry on your '69.
Old 6 Days Ago
The bike is level sitting on blocks. I see from digging more on this excellent forum that the tranny will also drain when the primary is drained, removing that plug is not required...do I have that right?
I don't see a level hole in the stamped (some call it a "tin" ) primary cover. But there is what I think is a drain screw on the lowest part of the primary cover surface. It's smaller than the screws that hold the cover on.
The 69 has a dry clutch, right?
So, button everything up and throw in 24 ozs of 50 weight....do I have that right?
Bear with me fellas, I'm new at the Ironhead game. I'll have a hundred more questions.
Old 6 Days Ago
doodah man's Avatar
i always pull my plug first, then when it slows down i sit on the bike and hold it up right for a few minutes to get as much out as possible. makes opening the primary a little less messy. just a little.
do you not have a screw just forward of the clutch hump on the cover?
originally, yes. very possibly oil soaked now from leaking through the clutch basket rivets, etc...
if you've got the primary cover off still, it's a good idea to check chain tension and the condition of the chain skid shoe. replace as necessary.
Old 6 Days Ago
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Yes Captain, you assume correct. The circled is the primary drain, the other is the trans drain and you will find another on the right side for the motor. You really don't need to use them at all. If you are careful , you can use them but as stated, they do strip and cross thead easily.
If your bike is on the side stand, once the primary cover is removed, most all oil will come out. The rest(1 oz or 2) doesn't matter. I use a little more than the 24 ozs. the FSM recommends. 28 has been my number. I have found no ill affect using a full quart, either.
Ok, now I'm revived
Old 5 Days Ago
the level hole is a 1/4'' bolt with a 7/16'' head.that small screw is not a drain screw.it also holds the primary cover on.dry clutch from the factory in'69.
