0 Rear brake help please!!!!
Last Post: Sadsack
Last Post: Whitewalls
0 Boardtracker Project
Last Post: JonesL
0 **DK Custom- *NEW* Sportster Slip Stream Skid Plate-10% Introductory Savings**
0 Replacement clutch discs
Last Post: sleighcrane
0 79 Engine Rebuild
Last Post: Peteroo
0 Harley being delivered next week
Last Post: conv90
0 How old are you?
Last Post: RandyMac
0 Electronic jet kit
Last Post: Jordan5150
0 hey y'all
0 No spark
Last Post: Dave L
Last Post: cotton1
0 Who owns a XLH1100 Sportster?
Last Post: jayel
0 Riserless riser bars
Last Post: Dave L
0 Issue that has me stumped
Last Post: Etienne_NL
0 Soccer question
Last Post: stalkie
Last Post: paulc
Last Post: RKN
0 Thought my clutch went out or tranny, was front pulley
Last Post: Screw Loose Dan
billib (64), Scar (59), koolblue, Spor-T-1 (55), Choppershed (54), Nemo DeNovo (52), harman35 (50), Wannabee (50), crackermank (48), WORM (42)
  #31
Old 1 Day Ago
Bored now Bored now is offline
Sportster/Buell Model: 883
Bored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond repute
Damn, I would have put money on the sensor, your description is absolutely spot on for that failure, one last thing to check is the connection to the sensor is clean and tight with no corrosion, long shot but no cost. When the spring plate goes you normally know because it drags and getting neutral becomes a pain. Good luck finding the problem.
Old 1 Day Ago
The Crusher's Avatar
The Crusher The Crusher is offline
The Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond reputeThe Crusher has a reputation beyond repute
Are you still dipping into the 800-900 RPM range?
You can't keep a good man down......... unless you tie weights to his ankles.
Old 1 Day Ago
60Gunner's Avatar
60Gunner 60Gunner is offline
60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future60Gunner has a brilliant future
Other than the split second or 2 at a specific rpm where the handlebars vibrate, mainly the left side, everything is A1 spot on. I mean it doesnt miss a beat. Ran it hard yesterday morning. 80-90 mph for 50 miles straight and it wanted more.
Maybe I'm making more of it than what it is.
05 1200C Tuned w/custom timing map 'Viper2'
Dragtron II/K&N filter/Cycle Shack pipes/
Khrome Werks 4"baffles/44/185 jets/N65C needle
Old 1 Day Ago
wedge's Avatar
wedge wedge is offline
It's called a CKP although CPS would maybe have been better, and how did you eliminate it? Last I heard you were waiting the 5 days for the dealer to get the correct one in.
Old 23 Hours Ago
60Gunner's Avatar
Picked up the shorter one.
Old 14 Hours Ago
Jollly Rogers Jollly Rogers is offline
Jollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond reputeJollly Rogers has a reputation beyond repute
CPS is a cam position sensor. CKP comes from CranK Position.
Some SAE Engineer made that call many years ago. Or possibly a committee. Since the MoCo adopted a lot of GMs electrical architecture they copied the shorthand too.
Joe
Old 5 Hours Ago
60Gunner's Avatar
Well it only has one so. Some engines used to have both. I don't think any does anymore. I could be wrong.
Pulled my carb last night. The plate was binding slightly by the ports coming off idle. This was all the way closed tho which it never is once the idle is set. The idle port and a couple of the other holes looked a little gummed. Cleaned it up good.
I'll start over adjusting it. Could've had a slight intake leak too tho the propane test didn't indicate a problem but the front plug appeared leaner than the rear on the ground strap but the base ring both looked the same, a little rich maybe. That's the idle. But I turned it up and I think it got into the off idle ports too which would explain that.
What about the MAP sensor?
