0 Identity crisis
0 keihn setup at Altitude
Last Post: Roaddawgie
Last Post: xraytoken
0 Missippi Gulf Coast here.
Last Post: sprink
Last Post: fafcpa
0 Fork Oil Measurement
Last Post: Cyclone14
Last Post: Desertfox
0 NRA files for bankrupcy
0 Who runs (or has run) a Barnett Scorpion Clutch?
Last Post: Scott
0 Newbie seeks smoother ride
Last Post: 45Brit
0 Carb Air Vent hole cracked
0 Removing Rear Shock
0 63 XLCH revival
0 Year help on ironhead confused
0 My Wife Says …
0 Boardtracker Project
0 Handlebars
Last Post: Dr3wDrop
0 Please School Me On Carbonite Clutches
0 mississippi queen video
0 motorcycle on lift for two+ years
Last Post: Akdawg
0 New from Ohio
Last Post: Roscoe13
0 my sunday driver...
0 Rebuild a 2 stroke in 9 minutes :)
Last Post: 3sporty53
steve yorke (63), edman (55), Hudsonator (53), kozman32 (53), R3DN3X (51), gmcsid (50), mitch (45), Txngrg87 (34), Gotenfan (31)
Old 4 Days Ago
rocketmangb's Avatar
Like to see that dyno sheet.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 3 Days Ago
Heres a 1250 flat top w/560s and home ported XB heads we did a few years back
Running V&H Side Shots,42 Mikuni,Daytona TC88A custom map
This dyno run has been posted a number of times (nothing wrong with that) and every time I see it I think it's a text book example of a carb that needs (for this engine) a smaller main air correction jet.
Old 3 Days Ago
There are no air jets on an HSR Mikuni
Old 3 Days Ago
Not even a pressed in jet / restriction in the air passage from the carb mouth to the needle jet? Most Mikunis have a pressed in or replaceable jet. I don't have a flatslide Mikuni to look at.
Old 3 Days Ago
HSR has a non bleed needle jet so the air jet is blocked off
I have not found a bleed type needle jet for the HSR
Old 3 Days Ago
That's unfortunate.
Old 3 Days Ago
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Originally Posted by hbkeith View Post
mine has Hammer 600 cams ,1275, BFH 883 heads , S&S D , 125 HP , would not even want to try riding it on the street though
Any chance this is your bike?
Sent from the 1340 power
Old 2 Days Ago
That's unfortunate.
Thats not to say you couldnt drill the needle jet to make it bleed air,there are air bleed jets that will fit the HSR
Old 2 Days Ago
wedge's Avatar
wedge wedge is offline
In this case, we sacrificed static cranking pressure to run the 560's. I think that is part of what you are seeing. Those cams are not designed to run with flat tops, but the bike is really fun to ride after you get it started. It will not start at all after sitting a couple of weeks with a slightly low battery. It always needs a full charge to get over the sitting period. Once you get past that it will start good until you let it sit for a while again.
The plan was to use 570's, but I already had a set of 560's and once you ride this thing with 560's there is no going back. I think I have dents in the back of my skull from my eyeballs slamming back against it.
Old 2 Days Ago
I dunno. I was just making an observation. Seems this type of AFR curve appears semi-regularly with HSR's. From ~ 3,600 rpm up (in this case) you see it get progressively leaner. Something emulsion tubes and air correction jets are used to correct. I didn't realize the HSR's don't have that air correction system.
