5 Mick Off Line
Last Post: randy3934
0 [B][I]Most embarrassing bike moments[/I][/B]
0 Calling all "Long Frame" riders...
Last Post: Jeff
0 time will tell, but...... (blacked out: fad?)
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 2021 Harley sportster 48 front fork cover and gaiter install HELP!
0 Need Correct K & N Filter #
Last Post: Steve S.
0 Pushrods Won't Hold Adjustment
Last Post: IronHeadRon
0 Engine tapping noise
Last Post: onadraw
Last Post: thefrenchowl
0 trans door ?
Last Post: rocketnorton
Last Post: oldschool
0 Greetings from Dead Moanes..er Des Moines
0 Any old helmet users?
0 Pawl spring or shifter?
9 Knock heard and felt through handle bars
Last Post: XL_1200C
0 Aermacchi Parts
Last Post: Bigshankhank
Last Post: Texas78028
Old 21st May 2022
kuch73's Avatar
kuch73 kuch73 is offline
kuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud ofkuch73 has much to be proud of
Default 2007 1200 low idle when hot...
My 07 1200 just started to get a real low idle when hot and sometimes dies at lights and stop signs. It starts right back up no issues. This seems to be intermittent. I just installed VIEDs and also added more tension to the throttle body return spring for a little more resistance on the throttle. I found the stock spring to be real sensitive to bumps and turns and such. I checked for codes and only have P0131 and P0151 which are both O2 sensors reading lean, which should be normal with any IED install, but no other codes. I just ordered a new VSS as I am also having issues with the speedo dropping off intermittently, as well as ordered a new CKP just to replace it. But, any other ideas as to why it may be having an intermittent low idle. Thoughts, thanks
Old 22nd May 2022
Air-Cooled Forever
Dual or single throttle cable?
Old 22nd May 2022
kuch73's Avatar
it's a dual cable, maybe I can just turn the idle screw out a tad
Old 22nd May 2022
Air-Cooled Forever
The bike is supposed to idle around 1100rpm, warm. I know, it seems a little fast but it's a Sportster and not a BT. So with FI, I assume the idle is about 1400 rpm for a half minute or so, when cold.
Old 22nd May 2022
Originally Posted by kuch73 View Post
My 07 1200 just started to get a real low idle when hot and sometimes dies at lights and stop signs... I just installed VIEDs...
Did this start right after you installed the VIED's?
Old 22nd May 2022
Have you checked the Idle Air Control?
http://sportsterpedia.com/doku.php/t...le_air_control
For Sportster Tech Info:
Old 22nd May 2022
kuch73's Avatar
I installed the VIeds and added more tension to the throttle spring at the same time, but also reading the sportsterpedia page it mentions that the IAC gets its signal when the VSS is 0. As I am also getting erratic speedo readings maybe my VSS is the culprit.
Old 23rd May 2022
kuch73's Avatar
I removed the Vieds yesterday and went for a ride this morning and did not have any issues. I have also read on a few threads here that many run these at their minimum setting, which gives about a 14.3 AFR. I had them set to the recommended 50% setting which gives a 14.0 AFR. I am thinking that this is too rich for my ride and is causing it to load up some at idle when hot. I am going to put them back on and turn them down to their minimum setting and see how they do. One thing though is that the part throttle popping and decel popping is back, so they are working in that regard. I will report back tomorrow on the results.
Old 23rd May 2022
Bluto Bluto is offline
Other Motorcycle Year: 1973
BTW the correct way to adjust the throttle cables on an EFI Sportster is not obvious, or wasn't to me anyway.
Hammer Performance shows how to do it right...
https://youtu.be/M6Ee5aCifxA
Old 23rd May 2022
Andy56 Andy56 is offline
Andy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond repute
I like videos that reinforce an idea or show tips and tricks that fully explain what HD mean or a better way to get the job done...
The idle cable apparently needs to be adjusted with the steering pointed fully to the right.
Reading the manual after you have the throttle butterfly fully open the grip should be released and the adjuster should be turned another 1/2 to 1 turn.
