0 Finding an accessory power source
Last Post: vagrant318
0 Figure Machine external breather
0 Head bolts and conversion
0 Rocker cover torx
Last Post: Bikeaholic
0 su carb question
0 Changing engine oil
Last Post: tussuck
0 Stretched Swingarm
Last Post: Racepres
0 spark plug wire ohms
Last Post: 1Scooter
0 Swingarm bearings - boy I'm glad I looked at them
0 DYNO TEST RESULTS: SE 58mm Throttle Body
0 LED headlight caused problems
Last Post: dayypete
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: hexnut
Last Post: Bow only
Last Post: koolbreeze
0 Bigger rear Pulley
0 Swingarm??
Last Post: Racepres
0 my recent ebay purchase
0 derby cover adjustment spring broke
Last Post: burely
0 Plug for Siren
0 HD spares and parts availability
Last Post: doc martin
0 Who Runs Turn Signals?
Last Post: Tincan
0 fork reflectors
0 '86 1100 basket build
Last Post: Onlybckroads
Mr.Gordon, rayzer13 (57), GrumpyCoyote (51), billet93 (47), beast1 (46), Barney_rubble23 (46), DDT (42), mgaworecki (41), superman5a (39), Phoenix81 (39)
Old 10th January 2020
Ethal iron Ethal iron is offline
Ethal iron is an unknown quantity at this point
Default Head gaskets
Are the hi compression head gaskets any good?I'm taking the heads off to clean them up and just wondering if I should use stock gaskets or try the 0.020
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
High compression thin (0.016) copper head gaskets will bump up the compression ratio about 1/2 a point. For the later emission engines that came with lower compression pistons. Works on all Ironheads. Nice thing about copper head gaskets is they are reusable after you anneal them. I'm running 0.016 copper gaskets in my 77 with 9.0:1 pistons.
Are they more prone to blowing out?
What? Are you putting nitro in it?
Not a very common failure. I've never had one leak.
Clean stuff properly and check for straight.
And I prefer the copper because it transfers heat very well.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Any of them will blow out if they aren't torqued down correctly of the faces aren't flat.
Thanks, I'm ordering them today
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
While the heads are off if you are concerned with compression you could cc the combustion chamber to verify they are identical. Then you could have head gasket surface refinished to ensure no warp. If jugs are pulled you could also have that surface cleaned up. I've also seated the head in place on cylinder without a gasket and used a feeler gauge to see how much space there was for gasket.
this is very good practice.no surprises after you start the motor up.even better if there is no gap between the cylinder and head.
Ideally when the head is properly torqued to spec you should get the required crush on the gasket before fire ring on cylinder contacts the head. Fire ring should fit in head snugly but not bottom out before gasket has been sufficiently compressed to do its job.
I'm taking it apart tomorrow. Gaskets are on the way. Thanks again
