Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Hammer Performance
Last Post: toadfish
0 A thunderstorm -weather that is
Last Post: oupa
Last Post: Beelzeboss
Last Post: Spokane2303
Last Post: JKKO
0 Hello from Waipu, New Zealand
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 stock modded exhaust vs short shot
Last Post: elbozo
Last Post: Darkseacret
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Last Post: xkreedx
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
Default SE Street Performance Slip-Ons Pipe Test - Mild 1275
Special thanks to a fellow XL Forum member "Knuckles" for loaning us a set of SE Street Performance Slip-ons for testing!
First just to eliminate any confusion about what we tested, the above is straight out of the current (2019) SE catalog. The mufflers are marked individually as 80599-07 (front) and 80518-07 (rear), but the set is sold as 80503-07 as shown above. We tested the chrome versions. These are 50-state EPA compliant mufflers as you can see. Almost didn't need to wear my earmuffs.
Here's what we got:
The test bike is a 2007 XL883 Equipped as follows:
Comments:
Strong down low, but dies at 5000rpm as you can see. Quite similar to the result we got from the Cone 2:1 pipe test. This is typical of a restrictive exhaust, you hit a wall where you just can't pump more air through the pipe.
Comparison to the reference pipe. The Patriot is not the strongest pipe down low, and these slip-ons beat it up to 4400rpm or so. But the Patriot clobbered the SE slips-ons by about 21hp on top. That's not quite a record, because the Patriot clobbered the stock exhaust by 24hp and tied it down low. But it's still a lot.
If someone could just invent a pipe that performs like the SE Slip-Ons below 4400rpm, and performs like the Patriot Defender above 4400rpm, they'd have a great pipe!
Bottom line, put these on if you want a quiet, EPA legal exhaust, with good bottom end power. But they're not a good choice for top end power at all.
Click Here to Contact Me
rejeanprimeau's Avatar
Are they catalyst equipped?
Knuckles's Avatar
Knuckles Knuckles is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2012
Knuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond reputeKnuckles has a reputation beyond repute
I don't think so, I was running them on my 2012 48.
2011 Street Glide (LazyBoy on wheels) 2012 48 (Way more Fun!!!)
Usually the catalyst is in the front pipe.
andy_t's Avatar
andy_t andy_t is offline
Sportster/Buell Year: 2016
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
Makes you wonder if they actually flow any better than the stock mufflers.
Andy
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
Andy
It's pretty safe bet they improve performance over the stock mufflers.
From the Hammer test they produced more horsepower than the Patriot pipe up to 4,400rpm.
I run these mufflers on my Nightster and the improvement in low end is noticeable. They produce a proper Harley sound at a low enough volume to allow my wife and I to carry on a conversation from idle to highway speeds.
Since I've only got one good ear left and I'd like to keep it, I've stuck with these pipes.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
aswracing's Avatar
This test result is now posted on our web site: http://www.hammerperf.com/ttxlexhaust.shtml#sespslipons
Here's a pic of the slip-ons under test:
I don't bother with the heat shields when I'm testing, so ignore the ugly head pipes. They're the stock 2007 pieces, as is the mounting bracket/crossover, which you can't really see, it's behind the mufflers. I also don't mess with the footpeg and brake pedal assembly and front sprocket cover, that stuff is just extra trouble when you're swapping pipes.
Bluto Bluto is offline
Bluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to beholdBluto is a splendid one to behold
Thanks very much for taking the time to run these tests and post the results....have this exhaust and will likely stick with it as I don't want anything louder, good to see that at least the low rpm performance is strong
KGIron2442 KGIron2442 is offline
Sportster/Buell Model: Iron 833
KGIron2442 is an unknown quantity at this point
I was just wondering about this configuration. I wonder what would happen if you took the baffles out and put it those torque inserts?
