Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > The BUY - SELL - TRADE Zone
Last Post: toadfish
0 A thunderstorm -weather that is
Last Post: oupa
Last Post: Beelzeboss
Last Post: Spokane2303
Last Post: JKKO
0 Hello from Waipu, New Zealand
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 stock modded exhaust vs short shot
Last Post: elbozo
Last Post: Darkseacret
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Last Post: xkreedx
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Originally Posted by painterdude923 View Post
Yes almost all street riding. 520 chain drive, 21 48, deuce rear wheel, stock swing arm and lowered stock forks, 19inch front mag wheel for now.... waiting for my 120 hp setup, everything I need then sell my complete 110hp setup with crush XB heads, 560 cams, 45 mikuni with manifold, 1250 30degree big fin cylinders,ect.... help recoup some of the money for the new setup ya know?
Sent from my SM-T350 using Tapatalk
Oh yeah with the xr1200 crank has the 34 tooth sprocket so using 57 tooth
Hey madnss! Had a question for you. I bought a NEW A.I.M, it is a little different than what you guys are using. I don't really want to have to pull the primary off every time I want to mess with it to get it dialed in. Where did you get yours modified to access the clutch?
