Last Post: toadfish
0 A thunderstorm -weather that is
Last Post: oupa
Last Post: Beelzeboss
Last Post: Spokane2303
Last Post: JKKO
0 Hello from Waipu, New Zealand
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 stock modded exhaust vs short shot
Last Post: elbozo
Last Post: Darkseacret
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Last Post: xkreedx
  #1231
Old 5 Days Ago
Tinz's Avatar
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant futureTinz has a brilliant future
Following your project cyco....will be doing the same shortly, just a tank tho.
Old 5 Days Ago
cycowrencher's Avatar
I used the green craft foam from Micheals... Really easy to shape with 36 grit wheels. I finish sanded with 150 after the rough cuts. I am going to use fleece for the base layer of glass and the weave to finish it off. Don't know yet if the foam will react to the resin. I have some scraps to test on. If it does I'll probably paint it with latex paint then glass it. I glued the blocks together with this...
Sent from my LG-LS993 using Tapatalk
Old 5 Days Ago
I also picked up these... 1 7/8 for 2.5 inches necked up to 2 1/4 the rest... Less than 8 lbs...
Old 5 Days Ago
So much fun.
Old 2 Days Ago
Vohnsen Vohnsen is offline
Stripped. Trying to make my bike look alittle better. Now I've been looking at all yours on Instagram and here and they look awesome and mine looks like a wreck haha
Sendt fra min EML-L29 med Tapatalk
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Old 2 Days Ago
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
Did you already forget how mine looked in 2017 step by step. Little at a time
this isn't just a trend homie, it's a lifestyle...
Old 1 Day Ago
Air-Cooled Forever
Are you powdercoating the frame or painting it? If you're going to paint it, I'd put a little glazing putty in the really rough spots or bondo, if bondo's your thing. Makes the frame look smoother when painted.
Old 1 Day Ago
I will be painting it and I will try putting some bondo in the nasty parts
Old 1 Day Ago
Air-Cooled Forever
Good choice. I've always had better luck using automotive mixed paint than having it powdercoated.
Old 1 Day Ago
Tinz's Avatar
Ah nothing like a blank slate. That’s the way to do it. . Have fun!
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
