Last Post: toadfish
0 A thunderstorm -weather that is
Last Post: oupa
Last Post: Beelzeboss
Last Post: Spokane2303
Last Post: JKKO
0 Hello from Waipu, New Zealand
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 stock modded exhaust vs short shot
Last Post: elbozo
Last Post: Darkseacret
0 Fork Spring Rate measurments, sag and more
Last Post: pdavis5160
5 my 3D printed turn signals.. what would you print?
0 Frame-mount Danmoto baffle removal?
Last Post: Curbside
Last Post: davixlrtt
0 compression problems
Last Post: BWP 5p
0 02 sensor query
0 Chrome or Dark Custom
Last Post: frogg_nutts
Last Post: xkreedx
andy_t's Avatar
andy_t andy_t is offline
Sportster/Buell Year: 2016
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
Originally Posted by noxlyet View Post
That's interesting, the clamp on the fork tube appears to be the 49mm quick release clamp. I wonder if the same clamp would fit lower on the fork tube where the diameter appears to increase. If so, then it would just be a matter of matching the offset of the fairing brackets to the width of the fork tubes.
It is the same 55mm clamp used on the vrod muscle. Quick-Clamp 57287-07.
I dont have my bike here in front of me but i really don't think od changes from top to bottom tree.
Andy
Old 5 Days Ago
noxlyet noxlyet is offline
Sportster/Buell Model: none
Sportster/Buell Year: none
Other Motorcycle Model: CB 750K
Other Motorcycle Year: 1975
noxlyet is an unknown quantity at this point
Thanks Andy.
Old 4 Days Ago
J.P.'s Avatar
J.P. J.P. is offline
Sportster/Buell Model: 883/1250 NRHS
Sportster/Buell Model #2: 883c (Wife's)
J.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to allJ.P. is a name known to all
if you don't mind swapping out the headlight you'll have more options
2008 XL 883/NRHS 1250, 94 HP and 81.5 torque: Stage 2 heads, Flat top ceramic coated pistons, 536 cams, 10.5:1 compression, Progressive 14.25" 412's, Progressive fork springs, Intiminators, Screaming Eagle Heavy Breather, Custom headers by Justin at Bishop's Custom Cycles with a Dan Moto carbon fiber can, Storz Performance Tail Section, Chainsikle rear sets, Superbrace Fork Brace, Daytona Steering Damper, Jagg oil cooler, Flanders Low Cafe Bars, RSD 1 1/2" risers, 8" Headlight, Bar end mirrors, Sport front fender
Old 4 Days Ago
Air-Cooled Forever
That's an awesome looking bike. All it needs is some Harley or Sportster emblems on the tank done in that oxidation light blue color. (like the Statue of Liberty)
Old 4 Days Ago
andy_t's Avatar
Thanks Andy.
Hope it helps. Let us know what you figure out.
Andy
Old 1 Day Ago
ORCX's Avatar
ORCX ORCX is offline
Other Motorcycle Model: VFR1200
Other Motorcycle Year: 2010
ORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud ofORCX has much to be proud of
Andy
Thanks for the pn, I've been looking for an image of clamps for Roadster.
link and a diagram
https://serviceinfo.harley-davidson....3?locale=en_US
