0 XL Forum will now be the Suzuki Intruder Forum
Last Post: duffy
0 Mikuni 42 on 883
Last Post: Bow only
0 Mid West Meet & Greet
Last Post: Bow only
0 What if? race ITT 1250
Last Post: SLW210
0 15 min rides
Last Post: 201648Rider
0 68 XLCH - Insight Plz
Last Post: sleighcrane
0 anyone recognize these pistons?
0 Help me identify this bike
0 A Truck and Two Saddle Sores on Two Bikes to Jacksonville
0 Shaking front end
0 harbor freight lift
Last Post: stick shift
0 HF bike lift
Last Post: Tonyb65
0 Who runs 70wt. oil
0 2003 1275 BFH 120hp still pings when going full throttle
Last Post: stikflote
0 Who Runs Turn Signals?
0 Greetings from Denmark
Last Post: AKL1
3 How To Post Photos
Last Post: AKL1
0 Just saying G'day
Last Post: Coz
0 Xl1200c
Last Post: Joe_jeep
Last Post: Doc308
kanger, Leef (75), pwilson1204 (72), TomW (61), micke (55), rat481 (51), Jason2009 (49), runsummore84 (36), wishbone550 (33)
Old 15th June 2019
rugger2 rugger2 is offline
Sportster/Buell Model: XLH 1200C
rugger2 is an unknown quantity at this point
Default Battery reversed, bike dead
Uh, I installed my battery leads in reverse. Positive to ground and Negative to the starter. Now all electrics are dead. Where do I start trouble shooting? What was most likely damaged?
Old 15th June 2019
NLXL's Avatar
NLXL NLXL is online now
I think it depends on the year of the bike, but nowadays bikes are protected by connecting the wrong terminal by diodes (=current can only go one way). Check the fuse(s) first.
Maybe this will get you some idea's:
https://www.youcanic.com/article/jum...tery-wrong-way
Old 15th June 2019
rejeanprimeau's Avatar
Maxi fuse on 2001. Just change that big fuse near the battery.
Old 15th June 2019
@rejeanprimeau. Not seeing the 'big fuse' near the battery. Just the circuit breaker. Not finding one in my wiring diagram for this 01 Sporty. Any other suggestions?
Old 15th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
There's a big black rubber case it's inside of if its the same as 05.
Old 16th June 2019
NLXL's Avatar
Will this help?
https://www.youtube.com/watch?v=QrWk_Av_KMw
However, I don't know the year of that bike in the video. I got a '92 myself so I only have breakers. Don't know in what year they switched to fuses.
Someone will definately know here.
Old 16th June 2019
Originally Posted by NLXL View Post
All fuses are OK. No main fuse per wiring diagram but this year has a circuit breaker.
Old 16th June 2019
General Diagnostics - Including Won't Turn Over & Won't Start
http://sportsterpedia.com/doku.php/t...k:ref:genmsr01
Do you have a multimeter? Make sure all the grounds are clean and good contact....
Disconnect the Regulator to Battery Connector...
Then, trace power from the battery to the Starter Solenoid - Then to the Main Circuit Breaker (CB) - then to the Keyswitch...
If all of that is good continuity, then power on the keyswitch - Check for power from the Keyswitch to the Individual Fuses:
Accy Key Position .. should power up the Accy Fuse (ORANGE/White wire)
Run Key Position .... should power up the other Fuses:
---- Ignition Fuse (GRAY wire)
---- Instrument Fuse (ORANGE wire)
---- Lights Fuse (BLUE Wire)
If all that verifies good - you should have power on the system...
Then - test the stator:
Sportsterpedia - Check your Alternator/Stator
Then check the regulator:
http://sportsterpedia.com/doku.php/t...tage_regulator
Once all that checks out, then reconnect the stator to the regulator & the regulator to the battery...
Old 16th June 2019
Old 16th June 2019
Awesome! Thanks, I will do the drill.
