0 Stock (?) 1974 cobra style seat won't fit.
Last Post: thefrenchowl
0 2004 ICM
Last Post: tamaro
0 Getting Hammered
Last Post: carbonizedeyesockets
0 Proper XLCH
Last Post: 11B40
0 Your Favorite Style
Last Post: Kokopeli
Last Post: geekonabike
0 Do people notice your bike?
Last Post: Kokopeli
0 Black Bike Bible
Last Post: Kokopeli
0 It's me - Kokopeli.
Last Post: Kokopeli
0 Possible air leak?
Last Post: noprobrobb
0 01 sport 883 (Shortest Shocks)
0 Show us a picture of your truck
Last Post: RDHenley
Last Post: RDHenley
0 Power cones
Last Post: JonesL
0 T bars or Apehangers???
0 V&H Short Shots Pipe Test - Mild 1250
Last Post: robbie202
0 Help Identifying Old Screamin Eagle Slipons
Last Post: FiftySixer
Last Post: SwissXL
0 Help!!!
0 Spark plugs
Loneduck1, Doug (71), PAS858 (46), Clanure (42), FF95EMT (38)
Closed Thread
Old 7th February 2013
It's not how much hp you make that causes the wheels to spread. it is how many rpms you are turning. At 130 mph you probabaly were not even turning 6,000 rpms and you could have done it with 70 hp. With 140 hp you should be going at least 165 mph so I am expecting you to really step it up this year.
Old 8th February 2013
outside the box racing
Sportster/Buell Year: 99
Sportster/Buell Year #2: 2000
Other Motorcycle Year: 1991
Originally Posted by A 4 liter V8 eater View Post
I just put a dowel through the wrist pin bushing on of the connecting rods. As you turn the nut on the crank the dowel eventually hits the case deck and stops the crank from moving. wa-la
i could be wrong but seems you are still at risk of twisting with this method.
lol. i WAS running 7k 160+ in bonneville. on pump gas. on the deserted access road the week between BUB and WOS. BUB was a ID-10T error: sticky BOV and not knowing enough to recognize it, WOS was also an ID-10T error: going from 160+ on pump gas to 110k and trying to tune to it on the fly, on the runs.
not going to make THOSE mistakes again. Can't wait to see what I screw up this year.
Crank was twisted. .002 pinion side, .018 primary. i think i showed pics somewhere of the stator that had been ground down and shorted out by the tilted rotor.
a suitcase of coors light greased the rails right onto Crank Works bench to check my cranks.
luckily the stock ebay crank is within .003 both sides. but i am pretty sure i don't want to put another crank in cases that have seen that kind of abuse.
i really think that i am the luckiest guy on earth. something tells me that is catastrophic failure territory.
glad i have another engine.
video
http://www.facebook.com/photo.php?v=4701077079396
You planning on making Bubs again this year?
BUB and WOS with a week in wonderful Wendover in between.
We should see you there then and hopefully we both bring our A game so we can have a bit of fun.
Old 13th February 2013
p.s. this is the correct tool to pull a pinion gear. using jam bars is an express ticket to a fubar pinion gear. don't ask me how i know.
TGB #8
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Keep it going mister.
soon as i get some new bearings i will go the other direction with pics.
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Um, how does it go back together?
Seems it'd have to be braced and shimmed to keep from tweaking.
Never done it myself...
Sam
Closed Thread
