0 It's me - Kokopeli.
0 Hello from LA
0 Good afternoon!
Last Post: FiftySixer
Last Post: spamer80
0 Polished rotor/brake pad compatability
Last Post: Sparkes
0 Japanese Harley?
0 Battery ?
0 Questions for the dyno gurus
0 Dual disc along with fork upgrade
Last Post: 883-1250
Last Post: 11B40
Last Post: RDHenley
Last Post: Calcustom
0 Lifters Comparison
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: toomuchstuff
0 The parts are all here, now the fun begins
Last Post: herostar
Last Post: hexnut
Last Post: ThrottleBody
0 Cam position sensor
Last Post: Bow only
0 New intake flange design by Twin Motorcycles - must see
Last Post: Randy_rots
0 ultima electronic ignition
Last Post: Mission1
Old 28th April 2014
rottenralph's Avatar
Believe he did a leak down test on another thread. It would have leaked down really fast(immediately) with a bent valve.
Old 28th April 2014
rocketmangb's Avatar
Lifter bore is perfect.
The Rubbermounts use nylon ? bolt down anti-rotation blocks instead of pins.
Lifter did not rotate as far as I can see.
The other 3 cams and lifters are perfect.
Pushrods are perfect.
That valve is leaking like its bent or ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 28th April 2014
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
Hope you get her all straight out it suck when this happens .
Old 28th April 2014
splineman's Avatar
splineman splineman is offline
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
My '05 rubbermount uses capscrews threaded into the lifter boss as anti rotation pins along flats on the lifter body. Pretty solid setup.
Part No: 18532-00A anti rotation screw.
Old 28th April 2014
Bob s hog's Avatar
Could it buy chance with a taller lift come away from the the nylon guides or you got some serious binding in valve or spring or valve retainer hitting the top of the guide.
Old 28th April 2014
splineman's Avatar
Sorry guy's my mistake. The pins were replaced by an anti rotation device in '06.
My mistake......
Old 28th April 2014
Gcram399's Avatar
Gcram399 Gcram399 is offline
I agree with what you said. The lifter was not turned. When we pulled the cam the roller was aimed the right direction. No damage or marks to the anti-rotation cage. If that lifter turned it surely would have damaged that cage.
And what's even more curious is that the roller on the lifter still spins freely?
I left before George and Pete pulled the head but the leak-down did show a small amount of leakage at the exhaust valve. Not leaking real bad but it shouldn't be leaking at all.
George
--Thomas Jefferson
Old 28th April 2014
pittboy pittboy is offline
Sportster/Buell Model: 883 low and 883 custom
pittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nicepittboy is just really nice
Ouch that looks really bad, did that happen this weekend?
Old 28th April 2014
It started monday night
Just sounded a little "Funny"
Didnt ride it after that.
Just fired it up and it got worse every time.
Old 28th April 2014
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Someone educate me here...could either the valve spring binding or the hydrosolid lifter going solid when it shouldn't cause this kind of damage?
