0 HELP! Extra part found
Last Post: Yakcm2
0 Starting issues (No Spark)
Last Post: jimstogs
0 back to factory clutch
0 The forum got talent
0 15 min rides
0 Battery melt down
0 Common ironhead problems
Last Post: SLW210
0 1960 XLCH in the UK
Last Post: thefrenchowl
0 Hello from Tampa, Fl
0 Replacement Clutch/Rotor Magnets
0 Resto-Repair 84 ironhead
Last Post: Yochstein
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
0 Howdy ya'll
Last Post: joes95bobber
0 removing clear coat on fork lowers
Last Post: flthd31
Last Post: chilly
0 88ci Sport Rod
top speed, xlch
Old 8th April 2015
XLCHc*ntmagnet XLCHc*ntmagnet is offline
Sportster/Buell Year: 59
XLCHc*ntmagnet is an unknown quantity at this point
Originally Posted by StickFSMC View Post
What's a computer???
IDK what's that?
Old 8th April 2015
sportsterdoc's Avatar
Originally Posted by XLCHc*ntmagnet View Post
...compression haven't had it measured, how would I?
plugs are Black!
what are you thinking?
Compression: Worn rings or more likely valves not fully closing (a compression tester is available at most any auto parts)
Plugs black: Way too rich and/or maybe a very weak spark
Old 8th April 2015
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
throttle's good
fuel flow's great
plugs are Black!
Black plugs is a usual indication of too rich a mixture in the combustion chamber.
Either from too much fuel or not enough air.
Air cleaner clean?
Excessive pumping of the accelerator pump will cause a black looking plug also.
What size main jet in the old bendix carb?
Is the choke plate fully open?
Does it tend to drop while running the bike? Those detentes that hold it in position have been known to wear and allow it to drop down a notch or so.
As far as a compression check ,you need a compression checking gauge and then perform the test with an engine at operating temp(preferably), fully open throttle and turning it over(not starting it) several good turns.
Perform it 3 times and average it out.
Old 8th April 2015
Air cleaner clean?
All good stuff Fridge
Rep to you
Old 8th April 2015
Fridge's Avatar
Rep to you
Thanks, always a pleasure to help an ironhead wrencher and right back at ya.
Old 9th April 2015
randy3934's Avatar
are you advancing the mag after starting?
Old 9th April 2015
no, right now I have a static time, an old timer recommended it, what would you recommend?
Old 9th April 2015
Air cleaner clean?
air cleaner is perfect and i got an old giant round air cleaner so air flow is abundant. The choke plate is great, I never use it, and it is always up, I give it 2 1/2 squirts with the ol' accel pump to get her going, might that be the cause of my black plugs?
so now my homework is to get a compression gauge and pull apart the carb to see what main jet size I have, I'll get back to you as soon as I do, and Thanks a lot man, I really appreciate everyone's knowledge and time, you guys are great!
Old 9th April 2015
as an update, I pulled apart my clutch and put it back together with some heavy duty springs to reduce the slipping, I'm up to 72! baby steps I guess, but it's something
btw taking the baffles out didn't do anything for me, worth the try though so thanks!
Old 9th April 2015
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
Heavy springs may ruin your worm gear, unless its hardened. Whats your spring compressed height installed?(between cup lip and plate) should be 0.187, 3/16"
How about some pics of the first year street legal CH?
