0 how do eat an elephant,,
Last Post: JonesL
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 su carb question
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 Psychedelic '70s SPortster Chopper Pictures
0 What engine oil do you use?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: PetesPonies
0 How tricky is it to replace dipstick trim from oil tank?
Last Post: burely
0 Buell special
0 Happy Birthday Mrs. Folkie.
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
Last Post: XL Ed
0 Cleaning clutch
Last Post: tussuck
0 my recent ebay purchase
2 My 1275 Hammer Conversion..
Last Post: wrkdWS6
0 Iron-shed
Last Post: smokey 2
0 Frame bracket
0 top end noise
Last Post: lostNdallas
top speed, xlch
Old 9th April 2015
XLCHc*ntmagnet XLCHc*ntmagnet is offline
Sportster/Buell Year: 59
XLCHc*ntmagnet is an unknown quantity at this point
alright here she is guys!
Old 9th April 2015
jayel's Avatar
jayel jayel is offline
Sportster/Buell Model: xlh1100
Sportster/Buell Year: 1987
Other Motorcycle Model: Yam SR500
Other Motorcycle Year: 1978
jayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to beholdjayel is a splendid one to behold
ok static timing is just setting it close to where it needs to be to run, after it starts you need to set the timing WITH a strobe timing light in the ADVANCED position you move the mag body to the retard position for easy starting and then move it to the advanced position to run normally DO NOT run it in the retard down the hiway good way to burn a hole in a piston
where are we going and why are we in this hand basket? 1987 1100 XLH
Old 9th April 2015
sportsterdoc's Avatar
Explain?
Retarded timing provides less burn time, which is not fuel efficient, nor power efficient and may increase heat to the exhaust valves (more fuel still burning), but why would it affect the piston?
Holes in the piston are usually due to very lean mixture.
Not that retarded timing may not contribute to the lack of speed.
Old 9th April 2015
jayel's Avatar
Originally Posted by sportsterdoc View Post
Explain?
you are putting extra heat into the combustion chamber whether you burn a valve, burn the side walls of the cylinder, rings don't like thatand that will screw up the piston the motor is going to run hotter than it should
http://bobistheoilguy.com/forums/ubb...Number=1054743
Old 9th April 2015
wedge's Avatar
wedge wedge is offline
Compression: Worn rings or more likely valves not fully closing (a compression tester is available at most any auto parts)
Plugs black: Way too rich and/or maybe a very weak spark
Or the bad compression you suspected.
Old 10th April 2015
Interesting...never seen a motor run long term, extremely retarded.
I am usually trying to push the advance as much as I can without pinging.
Old 10th April 2015
If I were a gambler, compression would be the favorite.
Old 10th April 2015
randy3934's Avatar
If I were a gambler I'd say the OP doesn't know to turn the magneto after it's fired up.
just grab the magneto body and try to turn counterclockwise, it should turn and come to a stop that's adjusted on the bracket under the mag, if properly static timed that would be the running position.
Old 10th April 2015
Alright guys! re-timing my magneto sounds like the golden ticket. or at least some mph, while i figure out the compression. i feel pretty informed about mag timing after some research, I'll be able to do it with a multimeter instead of a strobe light, right? any tips for me before I start messing with the timing?
Old 10th April 2015
btw I took out the baffles and reset the idle mixture, ran it around some and rechecked the plugs and they aren't black anymore
