0 Oil amount
0 900cc Pistons
Last Post: Staffords
Last Post: Turbo Sporty 48
2 Your daily tunes...
Last Post: RDHenley
Last Post: ivanford
0 88ci Sport Rod
0 Help!!!
Last Post: rocketnorton
0 Stock pipes
Last Post: DéDé
0 Proper XLCH
2 Humble pie
0 A Day in the Life...
3 2005 XL883 Standard for sale
Last Post: SLW210
0 The last of a dying breed...
0 '81 Gasket/Rebuild Questions
Last Post: Andy Hog
dave (71), Miami (70), MnKevin (65), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
Old 31st August 2018
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
Default Mixing frictions
Which style is better and can a guy use a mix in the stack?
Racepres's Avatar
Racepres Racepres is offline
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
I would just call Kent at Energy One, and be done...
or?????
Sportster/Buell Year: 1988
Or ..........Barnett.
I suspect it is the fiction material that is the issue, rather than the fixing pattern. I am not sure what you would gain from mixing plates but
it should still work if the stack height is within specs. On the other hand I wouldn't mix them for use in a high output engine as different
materials reputedly offer different engagement properties and you want all the plates to heat/wear evenly. Try it, tell us what happens!
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
You can mix em. Trying to keep the stack height consistent? E-One has different thickness steels to help with that.
If there is NO SPECIFIC ADVANTAGE, why would you?
Do you already have a mix and are trying to avoid buying all the same?
Personally, I would only do it in an emergency situation - while ordering a proper matching set...
It seems to me, if any one friction has less 'stickiness' than the others, you're going to put a lot of usage on that one...
2 Relax
There is no differential speed on a multi stack clutch pack. How can one friction or steel get more wear?
The gap when the glutch is released will average out.
The only thing that would cause specific friction or steel wear would be uneven wear on the hub/drum splines. The spline irregularity could keep the clutch pack locally applied and also cause drag and hard shifting.
Joe
OK - I reconsidered...
It would actually be the more sticky frictions that would get the additional wear...
Without a technical argument, I'll just stick with saying that it's not something I would do...
2 Relax
Just going through my spares, inspecting/measuring steels and frictions, putting a 3rd spare stack together, was just curious.
Only 2 runs on a new Barnett stack, my 60' is where it should be ( mid 1.4 ), will see how many runs I can get before it starts going away. Hopefully I can finish the season on the new clutch, only 2 races left. Testing tonight, will be some cooler air, looking for a 10.2 and some better lights!
Sprtstr1200s's Avatar
Sprtstr1200s Sprtstr1200s is offline
Sportster/Buell Model: Sportster XL1200s
Sprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond reputeSprtstr1200s has a reputation beyond repute
Tinz: brand are those plates? Top one looks Barnett.
Yes I believe the top style are Barnetts.....Not sure on the wider ones, got a bunch that came with the bike, some were in a Drag Specialties box.
