0 Stock (?) 1974 cobra style seat won't fit.
Last Post: thefrenchowl
0 2004 ICM
Last Post: tamaro
0 Getting Hammered
Last Post: carbonizedeyesockets
0 Proper XLCH
Last Post: 11B40
0 Your Favorite Style
Last Post: Kokopeli
Last Post: geekonabike
0 Do people notice your bike?
Last Post: Kokopeli
0 Black Bike Bible
Last Post: Kokopeli
0 It's me - Kokopeli.
Last Post: Kokopeli
0 Possible air leak?
Last Post: noprobrobb
0 01 sport 883 (Shortest Shocks)
0 Show us a picture of your truck
Last Post: RDHenley
Last Post: RDHenley
0 Power cones
Last Post: JonesL
0 T bars or Apehangers???
0 V&H Short Shots Pipe Test - Mild 1250
Last Post: robbie202
0 Help Identifying Old Screamin Eagle Slipons
Last Post: FiftySixer
Last Post: SwissXL
0 Help!!!
0 Spark plugs
Loneduck1, Doug (71), PAS858 (46), Clanure (42), FF95EMT (38)
Old 18th November 2004
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Thumbs up What next- The need for SPEED!
I have a 1200R & would like to get into the high 80s or 90s in HP. What can I do-relatively cheaply $1000. to get there. I've done a few mods already and I'm at mid 70's...
Famous Quote" You want to go faster.....LOOSE some weight!"
gwcrim's Avatar
gwcrim gwcrim is offline
Sportster/Buell Model: 1200 Sport
Sportster/Buell Model #2: Cafe el Roadkill
Sportster/Buell Year #2: 199?
Other Motorcycle Model: KX520
Other Motorcycle Year: 1989
gwcrim has disabled reputation
1- port the heads
2- add cams
3- Cycle Shack Slip ons
That should get you into the 90s. Call NRHS, Zippers, or Headquarters.
~Crim~
I got the slip ons- porting the heads...whats that cost? Which cams?
collinsb's Avatar
collinsb collinsb is offline
Sportster/Buell Model: Custom 1200
collinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura aboutcollinsb has a spectacular aura about
Hi Dogman,
If you are running with no baffles, you could be losing HP!
Billy
Oh Yeah!
My motorbike is better than your motorbike!
My dad can beat up you dad!
Yo momma!
gwcrim's Avatar
Ported heads and cams would be less than $1000 on the low side. Each shop would have their own opinions about what cams to use. No one here has as much experience as the above mentioned shops. Call them and see what they recommend. I think you'd be happy with any of them. They'll be more than happy to talk to you and give suggestions.
Turbota's Avatar
Turbota Turbota is offline
Your might be a little short with a $1000 limit.
Nallin Stage 2 "Big Valve" Heads
$ 850.00 per pair using customer supplied heads.
http://www.nallinracing.com/headworkbuell.shtml
That leaves you $150
SE Cam Kit P/N 25197-04 (specific for the 04-05)
249 / 249 duration
.551”/ .551” lift
http://www.surdyke.com/hd/catalog.asp
$ 263.75 from this source
$ 324.95 MSRP
I am not an expert, but I don't think the head work alone will get you the HP your looking for. Think your going to need heads and cam ... The parts selection needs to work as a matched "combo".
Puts you a little over your price ... I hope you are not planning on paying someone for the install.
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Smile head work - cams
NHRS will do your heads- Stage 1 $550. Stage 2 $850. Stage 3 $1100.
Surdyke HD has SE "E" .551 cams $263(on the internet).
gwcrim's Avatar
Big valve heads aren't necessarily the ticket unless you are merely looking for high HP numbers. Smaller valves promote better torque. Stage I porting and a complementary set of cams on the new XB engine would be a VERY strong runner and a blast to ride in the twisties.
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to beholdstevo is a splendid one to behold
G'day Dogman
Just to back up what Crim has said
Nallins or Headquarters or Tilleys or a good local indy that ya can sit down and talk to.
The correct compression ratio is closesly linked to the cams you choose,the valve sizes and cams will mainly determine the VE (volumetric efficeincy) point or torque peak, which will give the motor it's character.
It's best to talk to whoever is gonna do the heads and go with their recomendations.
I have some customers that I put large cams and valves in and others that I keep smallish cams and stock valve sizes.
It depends on what the customer is using the bike for and his riding style.
I'm not gonna stuff Redshift 585's and a 2" inlet in a 1200 that gets riden 2 up on trips and never gets reved past 4500.
By the same token I wouldn't be using N2's and stock valves for an 88" drag motor.
Talk to a few shops and see what you feel is the best for you.
Old 20th November 2004
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
Originally Posted by gwcrim
1- port the heads
2- add cams
Ditto.
do the heads pick up 10 ponies..do the cams maybe 5 more...so the heads are the way to go...do you have the cycle shacks or some other slip ons?
