Last Post: Bored now
0 fp3
Last Post: 11alan111
0 Resto-Repair 84 ironhead
0 Digital odometer
Last Post: shrimp
0 No spark
0 xied or x14ied?
0 My 900: half-H, half-CH
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
0 Smaller turn signals
Last Post: lehel
0 86-90 regulator-rectifier on 2003 engine?
Last Post: lehel
0 Intake seals, glad I checked them
mcevoy, Dnight (54), alvin01101 (54), rahean (52), 2005883c (46), cliff883 (45), HotRodSporty (44), Wes Marshall (41), liquidice148 (34)
Old 20th November 2004
bigdogbark's Avatar
bigdogbark bigdogbark is offline
Sportster/Buell Model: XLH -(Hugger)
Sportster/Buell Model #2: XL (STD)
Sportster/Buell Year #2: 2004
bigdogbark has disabled reputation
Originally Posted by gwcrim
1- port the heads
2- add cams
3- Cycle Shack Slip ons
That should get you into the 90s. Call NRHS, Zippers, or Headquarters.
A good 2 into 1 header should add some HP; I would perfer to move slower on a limited budget and get quality. And with the 2 to 1 header he still should have a few bucks for a cam.
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Originally Posted by Narley
Ditto.
do the heads pick up 10 ponies..do the cams maybe 5 more...so the heads are the way to go...do you have the cycle shacks or some other slip ons?
I have the SEII slipons-no baffles
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
I have had my heads done, got Cycle Shacks and a set of cams plus an ignition and got 84HP at 6300. I think 90's is a little high in expectation unless you want to rev a lot higher. I saw a 1200R with 883 heads and 9.5 wisecos with factory cams make 80+ ft lbs at around 3K up to around 4300. I was impressed. Of course its HP #'s were low with the factory cams but the Tq curve was very impressive. This is the dyno from yesturday.
The red curve is with N2's and the green curve is N3's.
Here it is. http://xlforum.net/forums/attachment...tachmentid=108
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
Old 21st November 2004
Narley's Avatar
Narley Narley is offline
Narley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura aboutNarley has a spectacular aura about
If you get a buyer for the se II ,sell them. The cycle shacks (aka se I) are way cheaper and make more power. I had the bike on the dyno all day with my indy . we ran the se II with no baffles , modified unstruction, cut out little holes, sortened baffle and no bafffle...it was a fun day. the cycle shacks made better results with the baffles in!
I had the hq mild heads at 10.5-1 and the andrews N8 and the cycle shacks and got 83 hp.
txsporty's Avatar
txsporty txsporty is offline
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
txsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished road
barry1967,
What kind of head work did you have done?
barry1967's Avatar
It started with a radial valve job with a little back cut I believe, shrink porting the exhaust side, a lump of aluminum welded into the intake side and then cnc'd to reshape it to increase velocity and I had the springs adjusted for height and lbs. Also took off a few thousand'ths to square em up. Thinner head gasket. Cylinders honed to round and squared as well. About 10 to 1 now.
It cost me 800 for all that but he gave me a bit of a break cause it was the first 04 1200 he did. Normally I think it was a 1000 job.
Her's the link, http://www.johnsonenginetechnology.com/index.html
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
NOS and some big balls
"lord of the Night Lite"
thank god for darwin ;)
Old 22nd November 2004
Narley's Avatar
Yeah , nitrous...thats good for 20 -40 ponies and the kits are only about $800
flathead45's Avatar
children , don't try this at home
Old 25th November 2004
wickedsprint wickedsprint is offline
Sportster/Buell Model: zx-10R
wickedsprint has disabled reputation
truth..with your budget..NITROUS
