Last Post: burely
0 Seized 1200SPORT Fork Cap
0 Intake manifold
0 Screamin Eagle Wiring
Last Post: AntonieR
3 Shaky Dave Recovery
Last Post: Hornsmith
0 FS Front brake line from '03 45121-96A*
Last Post: slamtry
0 "S" model specific Q&A
0 900 heads contd..
Last Post: simonster123
0 Tank Paint Ideas
Last Post: MotorPete
0 Fuel tank urns
Last Post: ezmerf
0 wrong brake fluid
0 Trans corner fix
0 Anyone know where I can get one of these mini fairings?
0 98 s10
Last Post: ezmerf
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Oil hungry Iron Heads
0 Getting Hammered
Last Post: Bryan1976
0 exhaust gaskets
0 New member from snowy Colorado
0 new member
cobra0478 (76), Han (63), priell3 (59), Byrdman (55), jsta (53), YaeDio (52), chad.hart17 (47), doc (46), jfunk (46), lenainrouge (45), JohnDao (41), Razer883 (34), Slapchop68 (26)
how to, instructions, maintenance, service
Old 1st July 2008
BluePotato's Avatar
BluePotato BluePotato is offline
BluePotato is on a distinguished roadBluePotato is on a distinguished roadBluePotato is on a distinguished roadBluePotato is on a distinguished road
Lightbulb Sportster Service Maintenance Link Collection
Sportster Service Maintenance Link Collection:
Tools Needed for Sportster Maintenance:
Fix My Hog Sportster Tools Video (Need to complete free registration on site before you can watch the video)
"What Wrench Fits What" Tool List
Sportster Maintenance Log:
Excel Spreadsheet 2004 Sportster Maintenance Log
My Service Sheet (The site has a few demo service sheets that can be downloaded as PDFs. One of the sample bikes is a Sportster 883. Instructions for logging in to the demo account are on the site.)
Beginners Maintenance:
Bikernet Sportster Maintenance (not too detailed, but a good simple overview of Sportster maintenance with photos)
Oil Change:
Frequency = 1,000 miles, 5,000 miles, and every 5,000 miles thereafter
Oil Change Instructions with Photos
Oil Filter Removal Milk Jug Trick Photos
Expert Village Harley Oil Change Video (not Sportster specific)
Primary Chain Adjustment:
Expert Village Harley Primary Chain Adjustment Video (not Sportster specific)
Audible Whine Primary Chain Adjustment Method Instructions / Audible Method Summary
Visual Primary Chain Adjustment Method Instructions
Classic Primary Chain Adjustment Method Instructions
Clutch Adjustment:
Clutch Adjustment Instructions With Photos
Clutch Adjustment Instructions (The Easy Way) (not Sportster specific)
Clutch Adjustment Instructions (By the Book) (not Sportster specific)
Expert Village Harley Clutch Pack Adjustment Video (not Sportster specific)
Expert Village Harley Clutch Cable Adjustment Video (not Sportster specific)
Primary/Transmission Fluid Change:
Primary/Transmission Fluid Change Instructions
Expert Village Harley Primary Fluid Change Video (not Sportster specific)
Clutch/Throttle/Idle Cable Lubrication:
Plastic Bag Method Cable Lubrication Instructions (not Sportster specific) (scroll down 6/10ths of the page)
Traditional Method Cable Lubrication Video Part 1 (not Sportster specific)
Part 2 (not Sportster specific)
Part 2
Change Brake Pads:
Inspection Frequency = 1,000 miles, 5,000 miles, and every 5,000 miles thereafter
Replacement Frequency = When thickness is 1/16"
Brake Pad Replacement Instructions
Brake bleeding:
Frequency = When brake fluid shows compressible bubbles or when brakes start to feel squishy
Brake Bleeding Instructions
Brake Bleeding Video (not Sportster specific)
Further Information on Motorcycle Brakes (not Sportster specific)
Throttle/Idle cable adjustment:
Throttle/Idle Cable Adjustment Instructions
Expert Village Harley Throttle/Idle Cable Adjustment Video (not Sportster specific)
Spark plugs:
Replacement Frequency = 10,000 miles and every 10,000 miles thereafter
Expert Village Harley Spark Plug Replacement Video (not Sportster specific)
Reading Spark Plug Instructions (not Sportster specific)
Engine Idle Speed Adjustment:
Engine Idle Speed Adjustment Instructions
Air Cleaner Inspection/Cleaning:
Expert Village Air Cleaner Inspection Video (not Sportster specific)
Steering Head Bearing Lubrication:
Frequency = 20,000 miles and every 20,000 miles thereafter
Steering Head Bearing Lubrication Instructions with Photos
Battery:
Expert Village Harley Battery Check Video (not Sportster specific)
Fix My Hog Battery Voltage Testing Video (not Sportster specific) (Need to complete free registration on site before you can watch the video, then click to view the Softail sample video. The same procedure applies to Sportsters.)
Front Fork Oil Change:
Front Fork Oil Change Instructions
Progressive Fork Springs Installation:
Progressive Fork Springs Installation Instructions
Progressive Fork Springs Installation Instructions with Photos
Progressive 412 Rear Shock Installation:
Progressive 412 Rear Shock Installation Instructions
Carburetor Rejetting:
Rejetting the CV Carburetor Instructions
Sportster CV Carburetor Rejetting Instructions
Torque specs for common fasteners:
  • Spark plugs = 12-18 ft.-lb
  • Clutch inspection cover = 84-108 in.-lb
  • Primary chain inspection cover = 40-60 in.-lb
  • Primary chain adjustment locknut = 20-25 ft.-lb
  • Transmission drain plug = 14-30 ft.-lb
  • Fork drain screw = 13-17 in.-lb
  • Fork cap nut = 22-58 ft.-lb
  • Air filter cover screw = 36-60 in.-lb
  • Air filter element screws = 40-60 in.-lb
  • Rear shock bolt = 45-50 ft.-lb
2006 Sportster 1200 Custom Chopper Blue / Brilliant Silver
Last edited by BluePotato; 8th July 2008 at 16:40.. Reason: Added clutch adjustment links
Old 1st July 2008
BluePotato's Avatar
The above is a collection of information and instructions I have found on the internet for my personal use and for educating myself on how to perform basic maintenance on my Sportster. I am happy to update this as a living document and will edit my post to include any additions, corrections, or suggestions you may have. With respect to torque specs or maintenance frequency, everybody has their own opinion, but I used the factory recommendations and I don’t intend on editing those. My goal here isn’t to create a replacement for the service manual or even to provide instruction, but to maintain a collection of links to well-written and useful instructions on recurring maintenance tasks, Sportster-specific if available.
I own a 2006 1200C, so there may be a bias toward that model and year in the links but most of this information can be used for frame-mount, carbureted, or EFI Sportsters.
I am not responsible for the content of the links or how the information is used and I claim none of it as my own original writing. I’m grateful for the people who actually can write good instructions for the rest of us. If anybody is aware of good detailed instruction available on the web for other maintenance requirements, or better links for the items above, please let me know.
Old 1st July 2008
shotgun46's Avatar
Very good ! and thank you for taking the time to set this up for us !
Sportsters Rule ! :banana
Old 1st July 2008
wandrur's Avatar
wandrur wandrur is offline
Thx for the help, jackass
Sportster/Buell Model: N/A
Sportster/Buell Year: N/A
Other Motorcycle Year: 2007
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
Looks pretty sweet to me!
Old 2nd July 2008
SportySarge's Avatar
SportySarge SportySarge is offline
Sportster/Buell Model: 1200L
SportySarge is an unknown quantity at this point
I recently purchased an 06 1200L and now have approx 10,000 miles. I will be performing the service myself and this site is invaluable. Thanks
Old 3rd July 2008
warhog78's Avatar
warhog78 warhog78 is offline
warhog78 is on a distinguished roadwarhog78 is on a distinguished road
Nice man, I appreciate the time and effort this took!
"The distinguishing characteristics of mind are of a subjective sort; we know them only from the contents of our own consciousness." - Wilhelm Wundt
MODIFICATIONS
Dominator Forcewinder
Mikuni HSR42
Vance & Hines Short Shots
TC88A w/Turbota's Modified MAP 33
Microtach+
Old 3rd July 2008
Blaze's Avatar
Blaze Blaze is offline
Sportster/Buell Model #2: Short Chop
Sportster/Buell Year #2: 1962
Blaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to allBlaze is a name known to all
Nice post dude! Thanks for sharing! I know it had to have been time consuming.
This should be a sticky!
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well armed lamb contesting the vote!
In a world of deceit, telling the truth becomes an act of revolt.
Old 14th July 2008
lunloon lunloon is offline
lunloon is on a distinguished roadlunloon is on a distinguished road
WOW!
This is a very helpful thread!
Kudos to Bluepotato
Old 19th July 2008
TrashCanMan TrashCanMan is offline
TrashCanMan is an unknown quantity at this point
Blue Potato
Thanks for all of this information, great post.
Old 19th July 2008
donnieray's Avatar
donnieray donnieray is offline
Sportster/Buell Model: xlh 883/1250
donnieray is an unknown quantity at this point
Very cool indeed...just added the link to my favorites list.
Time tested. It just happened.
