Last Post: burely
0 Seized 1200SPORT Fork Cap
0 Intake manifold
0 Screamin Eagle Wiring
Last Post: AntonieR
3 Shaky Dave Recovery
Last Post: Hornsmith
0 FS Front brake line from '03 45121-96A*
Last Post: slamtry
0 "S" model specific Q&A
0 900 heads contd..
Last Post: simonster123
0 Tank Paint Ideas
Last Post: MotorPete
0 Fuel tank urns
Last Post: ezmerf
0 wrong brake fluid
0 Trans corner fix
0 Anyone know where I can get one of these mini fairings?
0 98 s10
Last Post: ezmerf
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Oil hungry Iron Heads
0 Getting Hammered
Last Post: Bryan1976
0 exhaust gaskets
0 New member from snowy Colorado
0 new member
cobra0478 (76), Han (63), priell3 (59), Byrdman (55), jsta (53), YaeDio (52), chad.hart17 (47), doc (46), jfunk (46), lenainrouge (45), JohnDao (41), Razer883 (34), Slapchop68 (26)
Old 5th May 2006
ron1200c ron1200c is offline
ron1200c has disabled reputation
Default vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
I have 2004 1200 custom I bought new in Feb, 2004. I love it but needed more power so I had the dealer do the stage 2 kit which included air cleaner, 44 mm carb, cams, exhaust and 7000 rpm ign module. This was done last year with 10,000 miles on the bike. This year I noticed an increase in vibration. It got so bad that the mirrors would blur at idle. The bike now has 17,000 miles on it and runs real good. I took it to the dealer to have them check the vibration. They were busy and had it for 2 weeks. After two of the mechanics and the service manager rode the bike, all said there was a slight vibration but it seemed normal. The service manager added that he had never ridden new rubber mounted sportster with that many miles on it and that may be what happens over time.
They didn't charge me anything and I got a free bike wash. When I got home I looked over the bike in the garage and noticed the large thru bolt in the fromt rubber motor mount. There was no thread showing where the nut was on the bolt. I removed the right foot peg and rear brake pedal to gain access to the nut. With a 1 inch socket on it I was able to tighten it up about 2 full turns. Guess what, no more vibration. Anyone with a similar proble may want to check this before taking it to a shop.
Old 5th May 2006
gymrat523's Avatar
gymrat523 gymrat523 is offline
gymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura aboutgymrat523 has a spectacular aura about
thanks, good to know
Old 5th May 2006
cadiero's Avatar
cadiero cadiero is offline
Other Motorcycle Model: BMW R1200RT
cadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to behold
Hey thanks, I'll check that tonight. My '04 has 21K miles on it and does vibrate a little more than when it was new.
Old 5th May 2006
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
It took two weeks for your stealer to NOT find it? Time for a new stealer?
Old 5th May 2006
OldFenderGuy's Avatar
OldFenderGuy OldFenderGuy is offline
Other Motorcycle Model: Dyna WideGlide
Other Motorcycle Year: 1996
OldFenderGuy is an unknown quantity at this point
Good information....
I'm not having an excessive vibration problem, but I'm going to check it out anyway.....
[i]2005 Sportster 1200C - Lava Red Sunglo
1996 WideGlide (FXDWG) - Metallic Lava Red
2003 Anniversity FatBoy - EFI, SERT, Dyno Tuned
1981 "Sturgis" Shovelhead (Semi Retired)
1949 Panhead Custom Chopper (More Than Semi Retired)[/i]
Old 5th May 2006
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
Thanks for the tip. I don't have a vibration problem either, but it will save me tons of time if I ever do.
2005 XL1200C
Those who trade liberty for security have neither.
Old 5th May 2006
oldmansbike oldmansbike is offline
Sportster/Buell Model: 1200Custom
Sportster/Buell Year: 04
oldmansbike has disabled reputation
My wifes 04 1200 custom has the same problem it vibrates like heck. I read this thread and went right out and checked the through bolt and sure enough it is loose. You can turn it with your fingers. So I will get right on that this weekend and hopefully that will cure it. Thanks Ron for the tip.
Old 5th May 2006
marcel's Avatar
marcel marcel is offline
Sportster/Buell Year: '96
Sportster/Buell Year #2: '05
Other Motorcycle Model: Softail
Other Motorcycle Year: '85
marcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to allmarcel is a name known to all
Don't forget to use Lock-Tite on every nut and bolt that came loose, if it did it before it'll do it again, only next time it'll happen in the middle of nowhere!!!
Old 5th May 2006
hybriDatsun350's Avatar
hybriDatsun350 hybriDatsun350 is offline
Sportster/Buell Year: '99
Other Motorcycle Model: Not yet!
hybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enoughhybriDatsun350 will become famous soon enough
See the problems you get when the engine isn't bolted straight to the frame! Jeez!
Nick
1999 XLH1200, Vivid Black....Trimmed cam cover, Thunderheader, Ram Flo 400, Pingel petcock, forward controls, black drag bars w/4.5" pullback risers, relocated front turn signals, Progressive fork springs, 4-piston HD front caliper, and a bunch of black powdercoated stuff!
Old 5th May 2006
883 custom 883 custom is offline
883 custom has disabled reputation
I'll check mine out as well, anyone know the torque for this nut?
