Last Post: joes95bobber
Last Post: Boil1337
0 opinion time (bike broke again)
Last Post: lostNdallas
0 Cases Full Of Oil
0 Blackstone HyperTek
0 We were robbed at gun-point...
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
0 69 oil pump breather timing mark
Last Post: 72 Ironhead XLH
0 BETTER Brakes for $214
0 tubing strength if pressed?
Last Post: JonesL
0 Timing
0 super b overflow
Last Post: rickmodee
0 Buy A new battery
0 On starting a new thread
0 Powerraythor conversion
Last Post: dewjantim
Last Post: Racepres
0 Speed
Last Post: eskimo619
0 Hello from Long Island, New York
Last Post: TheBreeze
Old 24th June 2009
jessearias's Avatar
jessearias jessearias is offline
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 1984
jessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nicejessearias is just really nice
Default Jesse's Best Head/Cam Performance Combo's
The reason I am putting this together is, that there is a lot of confusion when choosing the right cam to match your head modifications.
You may not agree with all this but, based on my experience and what others have done in the forum, plus actual dyno results, these are in my opinion, the best head/cam combinations for general performance use.
NOTE: To generalize the Stages; Stock and Stage 1 STREET, Stage 2 STREET/STRIP and Stage 3 HOT STREET/STRIP.
All combinations are based on using Buell Thunderstorm or Buell XB/1200R heads.
NRHS modifications are listed because they offer various types of progressive head modifications. For a detailed description of NRHS’s various levels of head work, please go to their website. This does not imply that you must use them exclusively, but you can cross reference their modifications to others shops simular levels of head work.
STOCK HEADS
Stock configuration except for the following modifications: Valve jobs, HD springs and retainers. Guide work for clearance issues (TS heads w/ 536 cams)
SE 497
SE 536
Notes: You really can’t push more through the stock ports and valves than a 536. Both cams will deliver nice broad HP and torque curves.
NRHS STAGE 1 TYPE MODIFICATIONS
This means porting only, no oversize valves. All the above modifications apply as well.
SE 497
SE 536
Notes: This is a great mod for the street and really optimizes the heads for the above mentioned cams. It will give a nice boost in power and torque.
NRHS STAGE 2 TYPE MODIFICATIONS
Better porting, larger valves and all the above modifications as well.
SE 536
SE 575
RS 585
RS 630/585
Notes: All the above cams will take good advantage of the better porting and larger valves. The RS 630/585 in my opinion will work better with this head than a Stage 3 type head. The smaller porting and valves (than a stage 3 head) would enhance its torque producing capabilities.
NHRS STAGE 3 TYPE MODIFICATIONS
This is a completely tricked out, custom built RACING HEAD with the biggest ports and valves you can stick in it.
RS 585
RS 643
RS 729
Notes: If, you are going to spend this much money on a head then, match it with a max output cam to get the most out of it. In my opinion, the RS 585 is the minimum size cam you should use with these heads to take advantage of the tremendous flow potential.
BOTTOM LINE: Don’t put Stage 3 heads with a SE 497 cam. Will it work? Yes. Will it run good? Yes. BUT, you will be leaving a lot of performance (and money) on the table. When you hear people complain that their bike only makes X amount of HP with mis-matched heads/cams, is it any wonder why?
Match your heads to your cams and make your heads WORK FOR YOU. When the cams and heads are matched right, the horsepower and torque are right there.
Yes, you need other complementing modifications and GOOD TUNING as well but, that’s another post.
Hope this helps you all out.
Old 24th June 2009
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Where do Andrew's N-4, N-6 cams fit in your findings?
Old 24th June 2009
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Good info. I'm still not sure what I'm going to do.
Old 25th June 2009
Quay Quay is offline
Sportster/Buell Year: '07
Sportster/Buell Model #2: Buell XB12Ss
Sportster/Buell Year #2: '09
Other Motorcycle Model: Hayabusa
Other Motorcycle Year: '99
Quay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the rough
I think you should add in a bump in compression to match more aggressive cam grinds.
Also,a competition valve job should be considered for folks who wish to stay with the stock cams or .497"'s.
Old 25th June 2009
drummerboy4as's Avatar
drummerboy4as drummerboy4as is offline
Sportster/Buell Model: XL883 - 1250
drummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nicedrummerboy4as is just really nice
Just for fun I'll list my setup and you can tell me if it's a good setup. I know it runs well but I'm always curious if it can run better
NRHS 1250 kit with thunder storm pistons
'04 1200R stage II heads with bathtub chamber (no angled squishband)
SE .575 cams
Mikuni HSR42 carb don't recal the jetting
AN stage II big sucker
BUB Rinehart 2-1
Daytona TC88a ignition
SE plugs
Accel wires
I spend more than 75% of my riding time above 3,500 rpm. I don't "race" but I do ride very aggressively.
EP  Up the Irons!
[IMG]http://i.imgur.com/dwJB1XBl.jpg[/IMG]
"Take most people, they're crazy about cars. They worry if they get a little scratch on them, and they're always talking about how many miles they get to a gallon, and if they get a brand-new car already they start thinking about trading it in for one that's even newer. I don't even like old cars. I mean they don't even interest me. I'd rather have a goddam horse. A horse is at least human, for God's sake." ~ Holden Caulfield
[URL="http://xlforum.net/forums/showthread.php?threadid=175003"]Link to my NRHS build thread[/URL]
Have wrapped exhaust? [URL="http://xlforum.net/forums/showthread.php?t=544763"]Please read[/URL]
[QUOTE=khaskins;2765309]"my bike scares the cars and they scream like little girls"[/QUOTE]
[QUOTE=rottenralph;1773182]Bees and balls don't mix.[/QUOTE]
Old 25th June 2009
blakjak's Avatar
blakjak blakjak is offline
Sportster/Buell Model: Honda CBR 929RR
blakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the roughblakjak is a jewel in the rough
Andrews N4's are the same cam as the SE 497's.
IMO - An N6 falls into the same category as the N4/497/536 but is optimized for high compression (10.5:1 or higher) and needs to be matched to a good exhaust system.
N8's will also probably be in the same category as the above.
N2's & N3's are good for stock heads.
Not to take away from Jesse here at all. Only trying to help and just putting this out there for inclusion if need be.
Old 25th June 2009
jessearias's Avatar
Default Thanks for the input
I reccomend the SE cams because they are very reliable and easy on the valve train. They are easy to install and perfect for use at the lower stage levels. (<Stage 2)
Some others like the Red Shifts and more agressive Andrews tend to be a little tough on the valve train. Granted once you are at Stage 3 level, it is heavy duty everything in the valvetrain at that point.
You can use the other cams as Blakjak pointed out (thank you) but, I was trying to simplify things. I didn't want to throw a whole bunch out and get everybody confused. Most of the cams listed are ones everybody is familiar with and have used most of the time.
Like I said, my reccomendations are not the ten commandments but, very reasonable suggestions.
DRUMMERBOY4AS: Mikuni, Stage 2/575 cams, TC88, 2-1 exhaust, good AC. Looks like a great combination to me!
[FONT="Arial"] Jesse :smoke [/FONT]
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
Old 25th June 2009
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Default 2008 Xl1200 N
Thinking about getting the NRHS Hurricane air cleaner. Vance & Hines 2-1 competition pipes. (Black of course) Leaning towards Fuelpak. What are your cam recommendations? What recommendations at all? Thanks.
Old 25th June 2009
grindbastard's Avatar
grindbastard grindbastard is offline
Sportster/Buell Model #2: xl1200c
Sportster/Buell Year #2: 2005
grindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the rough
#1 Are xl1200r heads advantageous over the heads of any other model, and are they adequate for a cam upgrade with a justifying performance gain?
#2 If so...which cams?
gb
"...they mostly come at night......mostly."
2005 XL1200R - Arlen Ness Big Sucker AC, Cycle-Shack slip-ons, #185 Main/#45 Pilot, DynaTek Dyna 2000 Ignition, Forward Controls, 12" air shocks
2005 XL1200C - Stock as F*#k.
Old 26th June 2009
Bob F's Avatar
SE .575 cams
BUB Rinehart 2-1
SE plugs
Accel wires
Dyno it yet? How had is it to keep the front wheel on the ground? Don't be a pic tease.
