0 88ci Sport Rod
Last Post: rubine
Last Post: Bow only
0 Wiring and the turn signal module
Last Post: motorfish
0 Proper XLCH
Last Post: sasquatch_38
Last Post: ThrottleBody
Last Post: 11B40
0 Exhaust pipes
Last Post: Oldmxdog61u
Last Post: toe
Last Post: toe
4 The no-debate OIL POLL
0 2005 XL883 Standard for sale
0 Power cones
Last Post: Scott
0 It's me - Kokopeli.
Last Post: rubine
0 The last of a dying breed...
0 Laying up
0 Spark plugs
0 Getting Hammered
Last Post: carbonizedeyesockets
0 Tapered Muffler Baffle Repair?
Last Post: duffy
2 Your daily tunes...
Last Post: RDHenley
Last Post: CaptainZoop
Last Post: Hornsmith
0 '81 swingarm internals
Last Post: Scott
dave (71), Miami (70), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
View Poll Results: Sticky or no sticky
yes make it a sticky 13 100.00%
not required as a sticky 0 0%
Voters: 13. You may not vote on this poll
Old 28th May 2007
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of light
Talking Thanks...
On my VOES it is surrounded by metal. UNless I can take the whole
metal off the VOES, then i'll have to hack saw the tip to get to the
adjustment screw. Thanks for the extra info. I'll take
a look and see If I don't need to cut. Examine if you will my
VOES and take a closer look.
Thanks again.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 28th May 2007
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
To try and answer your second question; the engine set-up and weight of bike and weight of rider. To help explain you need to be aware of the following, the heavier the combined weight of the bike and rider the more throttle you have to give it to leave the lights (think of the difference when you have a passenger) and this can effect the vacuum at that point which as Horse explained “may give a false reading”.
Then you have to consider the new compression ratio, which can also affect the vacuum at that point, which as Horse explained “may give a false reading”.
Just because john doe and his mates have their VOES set at 5.5 doesn’t mean that the VOES is working at it’s best, but it may have stoped or reduced the detonation and that is better than what it probably was like before they did the adjustment.
If you want to get the last bit of performance out of your bike after spending hours on the conversion and lots of $$$ then you can adjust the VOES to change the curves at the best possible time for your engine set-up and weight of bike and weight of rider and the LED light method is the best method that I am aware of.
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Old 28th May 2007
Question Gonna start asking more detailed questions...
Since the most likely candidate for this so far from I hear is Compression?
Then what does that have to do with air intake since that is how the
VOES is used? I'm starting to see a relationship compared to the volume
of the cylinder on the intake stroke instead of compression? Would
that better explain since the VOES vacuum is connected to the carb... for air intake... compared to when the intake valve closes and the piston moves upward for the compression stroke... "after" the air has flowed thru the
carb?
Sorry so detailed.
Old 28th May 2007
davidcar's Avatar
“Since the most likely candidate for this so far from I hear is Compression? Then what does that have to do with air intake since that is how the
VOES is used?”
Yes the VOES works off the air intake. The relationship between compression and air intake and the VOES is as follows;
1. There are two timing curves programmed into the ignition module.
2. One can be referred to as the normal curve and the other can be referred to as the aggressive curve.
3. The normal curve is used while cruising and accelerating slowly
4. The aggressive curve is used while under acceleration.
5. When you increase the compression of an engine this increase of compression can cause detonation/pinging.
The VOES aids in the prevention of detonation caused by an increase of engine compression by changing the timing curve of the ignition module at an optimum point.
Say you are at cruising speed (the normal curve is being used) and then you suddenly accelerate. The ignition module needs to change to the aggressive curve so as to allow the engine to produce the best performance but if the ignition module changes too soon or too late, two things can happen, you may not get the best possible performance/power and the engine may detonate.
carb?
Sorry so detailed.
Old 28th May 2007
Horse's Avatar
Horse Horse is offline
Sportster/Buell Model #2: XLH 883/1200
Sportster/Buell Year #2: 1995
Other Motorcycle Model: FXDBI
Other Motorcycle Year: 06
Horse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to behold
Just to clear something up. The VOES unit doesn't work off the intake directly, it works off the Vacuum generated at the intake manifold. Think MAP on a car, though it's a much simpler system. Like an on/off switch, once the proper vacuum pressure is achieved, the switch goes on, you get advanced curve, vacuum drops at the manifold, switch goes off, normal curve.
R.I.P. Brother
Mocha Mafioso
Old 28th May 2007
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
Groove -
Here's a pic:
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
Old 29th May 2007
Lightbulb Some how only a portion of the pict was there...
Originally Posted by Shamdog View Post
Groove -
Here's a pic:
Some how the image didn't all the way load. Looked like the whole pict
was there... but the latter part is brown like an error occured.
Thanks.
Is this the same mklsportster person that did a write up on his conversion?
I think I rember seeing something during a web search that led me to you
write up or something... but forgot the location... and what I was searching for.
Old 29th May 2007
Lightbulb Thanks...
Thanks for the edited photo location with pointer. On my VOES 2000 model year I looks like i'll have to either remove the whole metal peice our use a hack saw to get past the metal cover to get to the silicone and the adjustment
screw.
On a side note... how far or how much room is there if I need to remove some metal from the cover? 1/4" or more closer to the edge? I wouldn't want to cut thru the adjustment screw while cutting at the wrong spot.
Thanks.
Old 29th May 2007
Talking mlksportster...
Thanks.
I noticed your site I seen before from your pict link... and noticed
on your web site that the pict is also the same error. Could be my browser
but I doubt that. You might want to re-check your pict and see if it loads
fully intact.
I so far haven't noticed any pings detonation etc so far. A basic 883-1250
updagrade all else being stock except for SE HSR 42mm carb, SE 07 air cleaner like the force winder... and vance and hines straight shots exhaust.
Do I still need to perforem this mod? Or do I only need to perform this mod
if I notice pinging etc?
I came upon some jap bikes at a stop light and I blew them away till
the next stop light. Could be bike or rider experience... but with 1250 and my first impromptu stop light race... I asked him to get it on so I could
see diff from stock 883.
He might have got me in the LONG run... but I got him in the SHORT run.
Even though I here no pinging etc... should I still perform this mod?
Thanks for any advice or experience.
Old 29th May 2007
Horse's Avatar
You can't always hear detonation. The best way to tell is to pull the plugs. Black specs like pepper means detonation, silver specs means nasty detonation.
