0 Rear mount for solo seat?
8 New build - engine ping / gnarly vibration
Last Post: ironheed
0 Lengthen 49mm forks, Sportster 48 ?
Last Post: XL Dane
0 Adaptive headlight issues
Last Post: Billy1200
0 First Harley ...
0 Magneto insulating block removal
Last Post: Captain Johnny
0 'Floppy' Forks ???
0 Bendix insulator block
0 '69 XLH wiring question
Last Post: sleighcrane
0 Hagerty Insurance
0 Thread revival
0 After years of Japanese bikes I got a sportster..
Last Post: Michman
0 Memphis Shades Fats Drop-Top Windshield
0 77 XLT smokes a lot on start up
Last Post: Kingrabbit
0 Removing oil tank DIY?
Last Post: oldboy
0 Paint Code for 1976 Sportster
Last Post: Parker 1000
0 86 c I burning pistons
0 Show your bike next to a lake
Last Post: zimbros12
reinhard (65), randolph196 (64), dexter (63), Swamp Fox (63), drewsport (58), paintslinger16 (57), grumpy0868 (52), Prototype (40), Tustan (40), dustom_99 (37)
  #151
Old 29th January 2016
Thorsteenster Thorsteenster is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
Thorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of lightThorsteenster is a glorious beacon of light
Originally Posted by Uquackmeup View Post
I just completed a 150 tire install on a '95 Sportster. If interested, the info can be seen at
http://www.geocities.com/when_pigs_fly_mc/880.html.htm
He hasn't been on here since 2012, Geocities is defunct, is this posted anywhere else?
Old 4th February 2017
XLdreaming's Avatar
XLdreaming XLdreaming is offline
Sportster/Buell Model: 1200XLH
Other Motorcycle Model: FLHTK
Other Motorcycle Year: 2016
XLdreaming is an unknown quantity at this point
That link you posted is dead. I guess after 12 years it would be.
XL Dreaming
Old 6th May 2017
KC8YSG KC8YSG is offline
Sportster/Buell Model: 883-1200
Sportster/Buell Year: 95
KC8YSG is an unknown quantity at this point
well its time for new tires and the metz me880 are no longer out there. what tires too use now?
Sc00'ter Sc00'ter is offline
Sportster/Buell Model: 1200 c
Sc00'ter is an unknown quantity at this point
I know this is a very old topic with tons of info, my question is that I have access to a rear laced wheel and michelin commander 150/80 16 tire already mounted off a 2010 sportster, will I have any issues with that wheel?
Old 5 Days Ago
twohawks's Avatar
twohawks twohawks is offline
Sportster/Buell Model: 1200 Custom, 883 Brat, ++
Sportster/Buell Model #2: Hugger
Sportster/Buell Year #2: 1995
Other Motorcycle Model: Jeep Grand Wagoneer
Other Motorcycle Year: 85
twohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to alltwohawks is a name known to all
Hey Scoot'er
In lieu of someone knowing offhand, I would check the part numbers and run it down from there.
Try Ronnie's: https://partsfinder.onlinemicrofiche...ModelYear=2017
Scroll Down, select year, etc -check part for rear wheel on each bike.
If its close, then I think it will be about working the axle+bearing puzzle.
Of course, you gotta figure the "tire" dim will work as well (150 ..I think it'll work, but I'm not schmoozing data righ tnow and so uncertain. Obviously data is onsite here, and you can measure your situation for that.)
Just off the top of my head.
HTH
Nevada Sierras
On Road - Harley. °`°º~_ò^\o_/|\_†
'88 FXLR, '95 Sportster 883, '96 Sportster 1200c, '18 FLHCS
Off Road - |_\o||||o/_|
. 85-90 CJ/FSJs
Old 5 Days Ago
Don’t overlook the “Sportsterpedia “ as an excellant resource with these questions, you may be impressed!
Old 4 Days Ago
On the rigids most could mount a 140 without issue,(I ran Avon 140’s on the 2000 for years), a few could sneak a 150 inthere I believe the Metzler 880 was one of them, not sure if its’ still availible. The width dimensions were not written in stone, between different manufacturers and even different tire lines of a manufacturer you will find different widths. Just saying.....oh never mind
Old 2 Days Ago
OCRyder OCRyder is offline
OCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to beholdOCRyder is a splendid one to behold
You can get it to fit but not without some work. I just finished putting a 150 on my 2003 and I had to clean out the fender, no nuts or bolts sticking out, and I did a chain conversion. My shinko tire rubbed a little on the chain but the Metzler 888 clears. It's mm if clearence all the way around but nothing rubs so yes it is possible but it won't be a simple bolt right up thing.
Looks sweet though with a 150!
Old 2 Days Ago
Randy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to beholdRandy_rots is a splendid one to behold
Here is how I did 170 conversion if anyone interested
http://xlforum.net/forums/showthread.php?t=1578656
