Last Post: sprink
Last Post: sprink
0 Front brake hose
Last Post: Joesdaddy
0 Your trans/engine rebuild advice
2 Your daily tunes...
Last Post: RDHenley
0 Crank Seal Missing; Is My Engine Damaged?
Last Post: RDHenley
Last Post: rocketnorton
0 Problem on a trip
0 Chinee Ignition
Last Post: RDHenley
Last Post: keithnh
0 900cc Pistons
Last Post: davixlrtt
0 Top End Whirring Sound
Last Post: Jason's Sporty
0 Simplified Wiring and Bars
Last Post: wannabehero
0 Proper XLCH
Last Post: Bigshankhank
Last Post: RDHenley
0 TC88a help
Last Post: paulb
Last Post: keithnh
0 Gel in seat for rigid?
Last Post: mickey t
0 Willi is back!!!!
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: Greasyman
Loneduck1, Doug (71), PAS858 (46), Clanure (42), FF95EMT (38)
Old 26th December 2019
Sportster/Buell Year: 1969
RicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to beholdRicThompson is a splendid one to behold
Default cam lobes
Obviously cams wear. How much is acceptable? Take a SIFTON cam for example with nice broad lobes, how much wear on the corners is acceptable? How about a small patch of the hard layer missing? What can be done to salvage? Has anyone ever used or recommend a regrind service?
Hippysmack's Avatar
How about some pics and measurements?
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of lightkitabel is a glorious beacon of light
Does the roller over-ride the edge of the lobe?
Old 27th December 2019
GA_Ironhead GA_Ironhead is online now
FWIW, Black Widow Cams bought the old Sifton masters and equipment at auction. V-Twin bought the Sifton name. BW may be able to help you out. Blackwidowcams.com, now http://www.crazyhorsespeedshop.com/
Hazmat Life
That's good information. I will contact them. Thank you.
Old 30th December 2019
cams are surface hardened. yes they can be repaired but usually more cost effective to buy new unless you are reshaping the profile.
if you have radius ride, that needs to be corrected, should be nil. radius ride stresses the assy as contact angle will cause cam walk.
i have some high mileage p's that are showing some pitting but with hd quality back then, could have been there from the factory, if it fits>ship!
I've contacted several establishments on repairing my cams. From what I have learned they are repairable but it's not cheap. Fortunately #4 is the one I am most concerned with and the easiest on my bike to look at regularly. When it goes back together I'll break in the new rings and change the oil to a good synthetic. Hopefully a quality lubricant will give me a few more miles out of these cams.
Who's willing to do the work?
www.crazyhorsespeedshop.com/about-us-1.htm
https://www.americancustomcam.com/index.htm
https://www.crower.com/
All three have responded positively. I'm not in a financial position to have the work done.
Old 31st December 2019
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
If it's only at the edge of the lobe this may not be a problem.
The lifters should run on the middle of the cam lobe, not near the edge. With second hand cams you can often see just exactly where the lifter is running.
Having a hard surface layer mans if the cams are dropped onto a hard surface you can "chip" the surface on the side of the cam. If the chip isn't too big it may not be a problem.
keep a careful eye out for shiny metal when you do your oil change.
