0 Greeting from CNY
0 Shotgun Porn
0 Dynamic timing the 2000i?
0 Welding the sprocket to the drum? Can that work OK?
Last Post: KCinSB
0 Ignition problem?
Last Post: xElvis
0 Do you run MAXIMUM PSI?!?
Last Post: Edster
0 Please-66 sportster 4 sale-what do I Ask?
Last Post: spacecoast
0 73 Ironhead power loss/ popping
Last Post: Jakezeise
Last Post: Diogenes415
0 Along came...
0 Frame paint
0 Local noise ordinance
Last Post: trappnman
0 Clutch removal tools
0 Rattling sound in Primary '92 1200
0 Dyno Jet Target Tune 1
Last Post: Turbo Sporty 48
Last Post: paulc
0 Should I clean case for machine shop
Last Post: Screw Loose Dan
0 Tail of dragon
0 97 sportster
Last Post: Slick773
0 No start, pull fuse and reinsert...starts
Last Post: gaspasser
0 Push Rod Adjustment
Last Post: Dave L
  #1031
Old 14th May 2018
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Originally Posted by cycowrencher View Post
Biggest part of my off season budget...
Contractor screwed me. Had to raise front of form 22 inches. It was a lot of dirt to move.
I’m confused on what’s going on with the 22” raise? The slab had to be raised 22”?
Anyho, looks like you’ll be getting some concrete placed soon for your new shop! Awesome and congrats!
Old 14th May 2018
cycowrencher's Avatar
No, the jackass had 22 inches of slope in the pad....
Biznitch better shift now...
R&D Motorsports procut and flux with Bandit trap door. 2003 cartridge and 1-4. 91-95 5th and counter gear. This combo changes the tq multiplier ratio in the trans from 1.67 to 1.73. This should pick up a bit in the bottom and middle of the track. Currently installed is a 91 cartridge with a 2000+ 5th and counter. This is suboptimal as the 1-2 and 2-3 rpm drops are poop... Add the 1.67 tq multiplier from the 2000+ 5th and counter and you have crappy shifts and you cannot take advantage of the tq the twin makes at the front side of the track.
Tinz's Avatar
Tinz Tinz is offline
Tinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud ofTinz has much to be proud of
Looks like a nice piece Cyco....looking forward to hear how it works out!
gusm2's Avatar
gusm2 gusm2 is offline
Sportster/Buell Model: Cyclone M2
Other Motorcycle Model: Suzuki SV650
Other Motorcycle Year: 01
gusm2 is an unknown quantity at this point
Not cheap either by the look of it
11.34@116.85
MatHormell's Avatar
Sportster/Buell Model: XL883R
Very nice! Marks works is perfection.. Mine feels like an inline sportbike trans now, very happy with it.. Only issue I have had since, is it is nearly impossible to hit neutral for some reason.. Not matter the clutch adjustment or chain slack.. Haven't got around to figuring out what's up with that.. Remember reading he has a few spring options for the shift detent mechanism , may just be to stiff of one on mine
[SIZE="1"]
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
[SIGPIC][/SIGPIC][/SIZE]
Yes, it was half of next years engine budget...
Matt, back off the pawl adjustment a hair by going down on drill bit size by 2 steps.
