Last Post: MnKevin
0 1968 ex barn dweller thread
0 Sifton cams on stock 74 XLCH
0 Installing jugs finally but another Q
0 Opinions on Mallory unilite ignition
Last Post: Heff
0 my sunday driver...
Last Post: 84rzv500r
0 Microsquirt?
Last Post: Curbside
0 S&s
0 Better Brakes
7 Ironhead yes or no
Last Post: exexpat93
Last Post: iBloke
Last Post: Andy56
0 fork oil change with Ricor intiminators
0 Li/Ion battery in '03
0 Tools
Last Post: denguy
0 18” rear wheel mag
Last Post: Yourstrulythom
Last Post: gusm2
0 Arlen Ness F-Bomb Pipe Test
wlm (57), Greg81XLH (55), saylor01 (54), Alicia (52), latnyte (51), antonini (43)
Old 12th July 2017
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Default Choke cable with HSR 42
I have always been fighting with the stock choke cable being too long when installed with my Mikuni 42. It sticks out quite a ways past the mounting bracket.
When I push it back it is hard not to get it to bind or increase the idle speed due to the line flexing.
Has anyone else experienced this?
Would the Mikuni cable work better in a case like this?
Sent from my SM-G930W8 using Tapatalk
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
Old 2nd October 2019
t120r t120r is offline
Sportster/Buell Model: xl883r
t120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rough
I know this is an old post, but I have the Mikuni cable and it sticks out about 2.5" farther than it should. I'll be shortening the cable over the winter.
Did you ever find a solution?
jordan1200's Avatar
The solution was simple. I just pushed the cable onto the mount and made sure it didn't bind and stick and had the needed slack in the knob once installed. It actually wasn't a big deal as I thought when I posted this.
Sent from my SM-G960W using Tapatalk
Old 4th October 2019
There's no chance of that working on mine. I'll just shorten it myself over the winter. I'm sure a bicycle shop can crimp on a new ferrule for me.
