0 2007 883R From Sunny Old England!
Last Post: Skeezix
0 KBS tank sealer
Last Post: mikethebike61
Last Post: Knuckles
0 Better Brakes
0 starting rollers
0 Microsquirt EFI Conversion
0 82 XLH struggling for power
Last Post: BigMek
Last Post: jcro61
0 Forum member mug shots
0 Old new guy
0 77xl sportster
0 BEWARE Of SCAMMERS!
2 My 1275 Hammer Conversion..
0 "She" bolts
Last Post: denguy
0 Range With EFI 4.5 Gal Tank
Last Post: oldboy
Last Post: david.hanaga
Last Post: dodgetrucken
0 WTB 1200 motor 2004-2006
Last Post: seajay
garryd (72), Chooch (69), kicker (63), Calgaich (60), skinnyboy (58), RogerB, Tonyb65 (55), sunkenloot (45), scoobs48, zman69 (39)
Old 26th May 2019
t120r t120r is offline
Sportster/Buell Model: xl883r
t120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rought120r is a jewel in the rough
Thanks for all the replies. I think I'll stick with my HSR42. Maybe over the winter I'll switch to another carb if I need to.
Old 13th June 2019
Any suggestions on a baseline jet setup that I can use for initial startup. I have a wideband already and will fine tune.
Old 13th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
I thought the same thing with the CV being under 100hp. Boy was I wrong. I would've taken Rocketman's advice and gone with a 45 or 48 had I not gotten a good buy on the 42.
Old 6th September 2019
So this HSR42 has a #96 needle on the 3rd ring, #30 pilot jet and a 165 main jet. I did the first portion of the hammer break-in. Next is the 50 mile ride, under 3500rpm. Going to be torture.
seajay's Avatar
seajay seajay is online now
Sportster/Buell Year: 04
I think you will need a larger main jet.
Oh I'm sure it will all be adjusted. Gotta start somewhere though. I have a wideband on my bike, so I'll see what it needs.
60Gunner's Avatar
Nevermind Tomcat. He doesn't think you can have have max HP and a good running motor. Thats why he runs 551s. Yet he's telling you your cams and porting aren't good for power.
Rocketman lives on a dyno and knows what he's talking about.
wedge's Avatar
wedge wedge is offline
Originally Posted by BKB View Post
A smaller carb will give good throttle response in the lower ranges, but will fall off when it reaches it's maximum flow limit. A too large carb will stumble at lower rpm if it's given too much throttle, but will allow higher top end.
Exactly. In my opinion, I always work from the smaller carburetor with smaller high speed runners in the intake and smaller valves. It makes for a nice crisp running bike, and that's what most of us really want. Big numbers on a dyno don't address rideability. Naturally we don't want to loose the top end either, so basically the smallest carb that can handle the top end is going to be a great street bike if it's set up right.
wedge's Avatar
You should start with a huge main jet. You could leave the main jet on the bench and still tune the low to mid range. If you start with a main jet that is too small, you will choke off your ability to tune the low end and mid range. It will give you nothing but false readings and frustration.
The main jet is mostly a top end limiter, so at this stage, don't limit yourself. Once the mid range on down is good, then test the main jet and lower it in size a bit.
I learned this from years of dirt bike repair. There were a few times when someone complained that the top end was flat, and the rest was great. I found the main jet sitting in the bottom of the float bowl on those occasions. They vibrated out, and the only effect was the top end sucked. George tested me on this and removed his main jet then took a ride around San Bernardino. He found that the bike was fine up to about 80 MPH, then it fell flat on it's face. If he had just stayed below 80, he could still be riding it that way today.
On a 1250 kit with 30 degree squish, I worked on a bike that had a 165 main in it. We worked on the mid range and the symptoms were strange. The bike just fell flat at about 4500 RPM (felt like rich actually). Then once I saw what the main jet was we bumped it way up to a 190 I think. That woke the beast up fast quick and in a hurry. It caught me by surprise and I almost missed the driveway.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Yep. And when you already have an HSR42 why not try it before spending $$$ on a larger carb? If the 42 doesn't do what you want you can always go bigger later.
