Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
Last Post: koolbreeze
0 Head Porting 101
0 at least RDRS
Last Post: RDHenley
Last Post: ZCarFan
0 Powerraythor conversion
Last Post: RDHenley
0 BETTER Brakes for $214
0 roadside belt change
0 Blackstone HyperTek
0 [Ignition}Points in a 2000n evo
Last Post: lostjohnny
0 tubing strength if pressed?
Last Post: JonesL
0 Request for recommendations: Sissy Bar for chopped fender
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 super b overflow
0 69 oil pump breather timing mark
0 is a buell a harley
Last Post: Coz
  #31
Old 6th January 2016
fishman's Avatar
fishman fishman is offline
Sportster/Buell Model: M2
fishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the rough
Originally Posted by NRHS Sales View Post
ah now I understand. I think you should be able to change the bearings in your M2 wheel to 30mm ID and get an XB axle to solve the problem.
The outside diameter of the m2 bearings are to small. They aren't available with a 30mm inaide diameter.
Hesitation is not an option!
that sucks. Where are you located that XB wheels are expensive? They are cheap here.
fishman's Avatar
that sucks. Where are you located that XeB wheels are expensive? They are cheap here.
The Netherlans. Theay are aboit 300 uwd over heren that's without pulley and disk. Shipping from usa is also expensive....
the pulleys seem to be the expensive part don't they.
Old 9th January 2016
fishman's Avatar
Testfitted the M2 wheel. Belt is way too long. XB uses a 65T rear pully, the M2 a 61T. Both use a 27T front Pulley. Is de gearbox on the XB a different end ratio than te M2?
69xlch5213 69xlch5213 is offline
Sportster/Buell Year: 1969
69xlch5213 is an unknown quantity at this point
You will receive educated guesses here mostly from Buell owners. The M2 engine was mostly a stock xl 1200 mill from the Sportster assembly line. The XB was purpose built for Buell and had a major change in the rear engine mount and swing arm attachment point. The XB brings the swing arm pivot bolt closer to the rear of the transmission so the belt is much shorter.
If you weigh the sprockets with the belt it will be much heavier than the chain with the chain sprockets so the most flexible path is to go with chain final drive. This way the gearing can be altered to suit your needs. Typically US built bikes are geared too high for long runs on autobahn design roads.
Old 10th January 2016
fishman's Avatar
Old 11th January 2016
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
You will spend a lot more than $300 trying to make that M2 wheel fit. Best bet is to suck it up and get the XB wheel and pulley tbh. Otherwise you would have to bore the M2 wheel's bearing races to accept the larger bearings and then still find a 65t rear pulley to fit the belt. No such thing as a 124t belt as far as I know, to utilize the stock pulley.
Love is the never-ending act of forgiveness - Peter Ustinov
Phelan's Avatar
Too bad about putting a carb on it. Certainly doable, but I think it would be way cooler to put 07-up XL Delphi EFI on it and a Dynojet Power Vision, since you already have a crank sensor. That way you could also utilize the auto tune features.
Also, you may want to add a bit more clearance between the rear rocker box and shock mount. The motor moves a bit in vibration because of the isolator design, and if you ever have a rear isolator fail in particular, you will have some serious contact there. Also, the tab on the frame behind the shock needs to go as well, or it will hit and bind the shock. The shock moves back and forth a few inches during travel, because of the pitch and design. You will need to account for this during your fabrication process as well.
fishman's Avatar
The wheel is being bored this week. I found a 65t pulley and i ordered the bearings and bushings. All for under 150 USD
