0 front drum bearing fit
Last Post: laney
0 Speed
0 1200 conversion
0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
0 5 gal tank
Last Post: Magneto Sportster
basket, clutch
  #41
Old 15th March 2016
dave76's Avatar
dave76 dave76 is offline
Senior Master Bike Builder
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
I used an FAG 6009 2RS. Pretty expensive bearing at $49 but a good brand name.
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Old 18th March 2016
Sportster/Buell Year: 1988
Wow that was expensive for a FAG bearing. I paid about £16 for my last SKF 6009.
Regarding which way to fit the 7200 bearing see this thread: http://xlforum.net/forums/s...1688139&page=3
Old 18th March 2016
WI_duker's Avatar
WI_duker WI_duker is offline
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
51 bucks plus tax here in Milwaukee.
It's Hammer time
Old 27th March 2016
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Finished the bearing sleeve for the trap-door today.
Tore
Old 27th March 2016
juzyHD's Avatar
juzyHD juzyHD is offline
Bike Builder
Great Norse! I got mine too. I'll probably put my bike together this week.
Old 27th March 2016
hell-wart's Avatar
hell-wart hell-wart is offline
Sportster/Buell Model: Sportster 883 => now 1200
Other Motorcycle Model: Kawa Z 900 RS
Other Motorcycle Year: 2018
hell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to allhell-wart is a name known to all
Hi norseXL,
I want to do it on my 86 as well.
Do you have the outer diameter size now ? ´4´in your drawing
Old 27th March 2016
hell-wart's Avatar
Forgot to say that your tread is like scientific work.
Go on sending pictures please
Old 28th March 2016
norseXL's Avatar
Originally Posted by hell-wart View Post
Hi norseXL,
I ended up with just one thou under 2.5", with that I just needed to give the trap-door a little heat (aprox 50 C, 110/120 F ) and it did slide in without force.
I used Lock-tite too, since the fit was not a tight crimp.
Tore
Old 28th March 2016
hell-wart's Avatar
Thanks Tore,
do you think it will work with a inner diameter of 56 mm ?
I think there is enough space.
If yes, it possible to use a standard thick walled tube with AD:71mm ID:56mm
I also thought about a groove for a circlip to fix the bearing in the sleeve.
Old 28th March 2016
norseXL's Avatar
Thanks Tore,
56mm would be fine, as a mather of fact I think it was around there I ended up myself, it's not a critical diameter.
Retainer circlip shure would be a nice touch, but not realy needed, but if there is space for it, why not?
Tore
