0 points/condenser
Last Post: cxf
0 My New Daughter "Harley Dee"
0 What happened to the Wuhan virus?
Last Post: duffy
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: Magneto Sportster
0 low comp pistons spark plugs
0 A couple more noob questions (Fuel, EFI)
0 Wiring dual headlight help
0 Humiliating- I had to push my bike home
0 Michigan Thumb Run:
0 Gauntlet fairing on 99 Sport?
Last Post: 84cj
0 900cc Pistons
Last Post: 11B40
3 Start System Testing
0 883 Highway Speed?
Last Post: Bigshankhank
0 79 Ironhead with gear grinding start problem
Last Post: BigMek
Last Post: ivanford
Last Post: spamer80
0 2012 XL1200X minimun shock height
Last Post: motorfish
0 Kickstands
Last Post: Papi
0 2005 Customized Sportster with Wide Glide Front
Last Post: TheGreenMachine79
Last Post: DéDé
Last Post: Joe_jeep
0 New H-D Fully Adjustable Piggy Back Shocks And Fully Adjustable Fork Kit
0 DK customs suspension
Last Post: Bryan1976
cobra47 (73), nardo (61), stevo (56), myrl883 (56), h2ocreeker (54), erreoa (53), abodyjoe (51), MJK (44), bobII (41), motoxxx (35)
View Poll Results: Belt Or chain conversion?
Keep the belt 119 78.29%
Get the chain 33 21.71%
Voters: 152. You may not vote on this poll
  #111
Old 29th February 2020
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
SportsterPaul, thanks for the tip!
I'll order a new belt & fit it, my bike 03 so rigid, think will have to take rear brake master off as mounted beside front pully cover, undo lower shock mount & belt covers loosen axle, jack under right side of frame & jiffy stand down. be interesting to see how long I take. after changing for a new belt I might pack old belt the way you said & also pack all tools I use to replace. much thanks!!
2003 XL 88"
Old 1st March 2020
Highly-Dangerous's Avatar
SPANIARD
The trick with the belt is to put the new one on in the comfort of your home. Pack the old one as it is very flexible and easier to install at roadside. It will twist down into a nice three loop coil about 9” diameter and slip into a plastic bag for transport. To do it you grasp opposite sides of the belt an twist forming a figure eight, then work one coil down and towards the side and do another twist. Should end up with three coils. Easily done and quicker than it takes to try and explain it. I never leave for any over nighter without a spare belt.
Note taken. Thanks!
CLICK->>"Maintenance is as much art as it is science"<<-CLICK
Old 2nd March 2020
sportsterpaul sportsterpaul is online now
Please note: it’s not necessary to jack up the rear of the bike to do a change out. When installing the replacement it will be sometimes easier putting it around the front pulley and start it up the back of the rear pulley, you can then roll the bike forward,( much as we did when very young and put our chain back onto our bicycles), and it will slip into place. This also saves touching the axle adjusters to gain slack, and is why I advocate taking the used belt as a spare. You might also decide not to install the upper pulley guard until getting home. Just saves time on the side of a road.
Old 2nd March 2020
Much Thanks for the tips!!
Old 3rd March 2020
Premoter Premoter is offline
Sportster/Buell Model: Buell XB
Premoter is an unknown quantity at this point
I suggest you not to drive a bike with a broken belt, even for a short distance.
Old 3rd March 2020
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
If the belt is broken, I think it would be quite hard to ride it anyway!
Folkie
South East England Riders
Old 3rd March 2020
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Works ok going downhill...
Old 3rd March 2020
Folkie's Avatar
Brass Nut
I'll give you that one.
Old 3rd March 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Probably been mentioned.
Since not big twin. I voted keep the belt. If big Twin. Then I'd convert it.
Stock sucks.
Traveled to
Old 10th March 2020
F.W.I.W. while returning home from up north with a buddie,(on his GoldWing), we entered a road that had just been chip sealed. After approximately 5-6 miles I felt a lurching that got progressively worse, much like the belt was jumping the sprocket. I pulled into a roadside park, got my tools out and pulled the sprocket cover. It was then that I saw where a half dozen teeth had sheared off the belt. Buttoned it up and decided to try to get down to Linwood as there was an Indy that would be able to work on it. My friend ran ahead and ran interference at the couple of stop signs so I didn’t have to come to a complete stop, (hey, it is what it is), and we made it almost down to Pinconning. Teeth kept shearing off but I was able to get another 6 miles closer to help. Belt did snap and I coasted to a stop, called and a truck and trailer were dispatched to pick up the bike. Seeing that tow and repair bill led me to prepare for future trips with a viable back up belt. The next three I handled myself. Just saying......
