0 Kickstands
Last Post: c1skout
0 One more TSM question
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 points/condenser
Last Post: Whitewalls
0 Gauntlet fairing on 99 Sport?
Last Post: c1skout
0 What happened to the Wuhan virus?
0 Lets See Your Nightster
Last Post: vaquerodiablo
0 My New Daughter "Harley Dee"
0 What oil temp do you run
Last Post: 03SportyBoy
0 Humiliating- I had to push my bike home
Last Post: Hornsmith
0 Wiring dual headlight help
Last Post: Sportsnerd
0 883 Highway Speed?
Last Post: Hellbent_4
Last Post: Akdawg
0 A couple more noob questions (Relocating Rear Turn Signals)
0 A couple more noob questions (Fuel, EFI)
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: Magneto Sportster
0 low comp pistons spark plugs
cobra47 (73), nardo (61), stevo (56), myrl883 (56), h2ocreeker (54), erreoa (53), abodyjoe (51), MJK (44), bobII (41), motoxxx (35)
View Poll Results: Belt Or chain conversion?
Keep the belt 119 78.29%
Get the chain 33 21.71%
Voters: 152. You may not vote on this poll
Old 8th September 2014
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
Chain
No reason not to.
Old 9th September 2014
jimmydee's Avatar
jimmydee jimmydee is offline
Other Motorcycle Model: KDX 200
Other Motorcycle Year: 1989
jimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to beholdjimmydee is a splendid one to behold
Originally Posted by sportytrash View Post
When I'm sitting on the roadside with a broken belt it makes go insane. Think billy jack when the girl gets the ice cream cone shoved in her face. 100 miles out and not a damn thing I can do but call for help. Which is great if you have lots of friends . Myself I have mostly aquantinces. I realized long ago that if you truly have one good friend that you can count on you are lucky.
My Sportys my friend. Arnt you buddy. Hey, get back in the garage your leaking oil all over the carpet.
____________________________________________________________________________________________________________________________________________________________________________ 2006 XL1200C- Hammer Perf. 1250 kit w/ Crush ported heads, 1.900 intake valves, 1.615 exhaust valves, 560 cams, 30 deg. reverse dome pistons, Mikuni HSR45, SE heavy Breather, Hammer billet manifold, TC88A ignition, Samson Powerflow 3, Ricor vibranators, Superbrace, Avon air grips, Ricor shocks, Killer map by Rico, Michelin Commander II s., Traxxion Dynamics AK-20 fork cartridges. Oil leak.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Originally Posted by WI_duker View Post
Chain
No reason not to.
No reason to. Why spend money and time when it's not necessary?
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
WI_duker's Avatar
Belts are for pants
Old 11th September 2014
Sleeper Sleeper is offline
Sportster/Buell Model: XL883R
Belts are for pants
What are chains for? Dresses or maybe pansies?
Dirty Old Dog
Old 12th September 2014
roachhill roachhill is offline
Other Motorcycle Model: Ducati Monster
Other Motorcycle Year: 1995
roachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud ofroachhill has much to be proud of
Chains are for real machines of course, that seems obvious.
Old 13th September 2014
nucklhead13 nucklhead13 is offline
Sportster/Buell Model: 1000 xlch
nucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to beholdnucklhead13 is a splendid one to behold
My ride is a 1980 Ironhead, and it still has stock sprockets and chain. I think chains are stronger. Only hae to watch out when you adjust the chain. I sit on the ride with a back pack on to add as much weight as I can.
Old 15th December 2014
lucifer_mr2 lucifer_mr2 is offline
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Got one bike on chain, one on belt.
Chain wore out at 22,000 miles (well earlier, but that was when I replaced it). Easy job to do. Needs maintenance.
Belt is 50,000 miles old. Belt still good, slight pitting on the sprockets. Ride it in all kinds of conditions, including dirt roads. Have been pretty lucky with the rocks, and haven't picked any up.
I'll keep the belt on my Sportster. I like the lack of chain noise from it.
Old 16th December 2014
Russ Russ is offline
Sportster/Buell Model: d
Other Motorcycle Model: Bus pass
Russ is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of lightRuss is a glorious beacon of light
I've had two belts snap on me, what scared me was the complete lack of warning; belts looked fine, run fine and then snapped. I did the chain thing, can't really say I found any difference in the ride either in terms of noise or smoothness of pull.
I like the idea of belt drive but the thought of having another snap without warning put me off. It sounds like I was just unlucky but I'll still stick with the chain.
Russ
I've seen chains snap as well. Fairly new ones too.
