0 Backfiring
Last Post: David Kirkha
0 S&S Super E
Last Post: thecarfarmer
0 WTB 04-06 intake manifold
Last Post: beardo
Last Post: BestCoastXL
Last Post: b0fh
0 xl1200T
0 Ironhead Exhaust Poll
Last Post: Serious Blac
0 1968 ex barn dweller thread
0 2018 Iron 1275 Project
Last Post: Turbo Sporty 48
0 Do you blow dry your ride after wash
0 final drive front sprocket change
0 What Is the Advantage - Shovster?
0 Non-Starter, Compression Test Results
0 Iron 1966 XLRTT
0 Swing arm bearing change
Last Post: SportsterXLCH1967
Last Post: Maxwell#256
0 New here - compression test produced meh results.
Last Post: rocketnorton
0 What to do now? Ironhead clutch hub nut stripped
0 Iron 2020 wire tuck
Last Post: Dorretje
  #8441
Old 15 Hours Ago
Shows up as an error Jim.
Sorry, I'll try it somehow.
Old 7 Hours Ago
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
Dam it Jim : To error is human so get the green blooded freak to do it.
Old 3 Hours Ago
I can't get it to work. I need a geek. I can e-mail it, but not post it.
Old 2 Hours Ago
Graywolf Graywolf is offline
"EC-4008"
Error code - 4008 the forum does not have access and / or permission to access the files.
It could be a firewall error, or it could be that you have to log in before you can access the files. The only way to fix it so it will post on the forum is to either get it out from behind the firewall or else use your permission to save the files to your computer and then put them on a storage location that does not require a sign in.
And don't call me a geek!
Graywolf
Old 2 Hours Ago
"EC-4008"
You lost me at "Error code"
