0 Winter Sucks
0 Her indoors
0 Hello from NE Washington state.
0 Stabliser Tie-link 16232-04
0 Big Bore '03 883R :)
Last Post: t120r
0 1981 basket- restomod questions
Last Post: drumbrake
0 which plug for dual plug heads
Last Post: Jarlaxle
0 Mystery oil splatter in exhaust
Last Post: T_worth
Last Post: Bama Lee XLC
0 Shipping woes
0 Who's still riding???
0 In Tank Oil Filter?
0 Valve guide replacement SOP
Last Post: NHPS
0 04 Battery Cover on a 95
Last Post: F1J1
Last Post: sltm1
Last Post: Jarlaxle
Last Post: JKKO
0 Bushing alignment
0 Cometic gasket set part # ?
Last Post: T_worth
0 Posting Pics
Last Post: kmul
0 Help please!?!?! (Unidentified Spacer)
Last Post: bimbo
IronHead83, AMATRAVELER (57), ZYBAN (55), tom_ski (54), mid30 (53), im_justin_sane (51), DOZER (49), acman145acp (49)
  #1191
Old 5 Days Ago
cycowrencher's Avatar
Stock: 12 lbs. 17 3/4 in pivot to rear most axle position.
+4: 21lbs. 20 1/4 in pivot to rear most axle position.
+10 (jcros): (40+ lbs)on bike... 27 1/8 in pivot to rear most axle position.
+16 (New arm): 12.4 lbs. 33 3/4 in pivot to rear most axle position.
Sent from my LG-LS993 using Tapatalk
Old 4 Days Ago
Started tear down...
Old 4 Days Ago
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Talking
Sweet, whats your new w.b. going to be? Going to need a looooong chain !
Old 3 Days Ago
Im 66.75 now. I have to go a minimum of +4 just to run the new arm so I will probably make it an even 72. We do not have a wheelbase limit in the classes I run out here. Probably also going to drop rear to a 46 or 44. That will help shorten chain.
Just eyeballed it all up...
69.5 minimum with buell s3 trees.
71 is roughly middle of adjuster range.
73 is max with chain still having adjustment room for stretch...
Old 9 Hours Ago
madnss's Avatar
After a year of messing with the super d carb it all came down to running a two step to get the carb to hold rpm. Pretty excited
Old 5 Hours Ago
madnss's Avatar
https://youtu.be/37NNloLal78
I’m only light years behind xldukes and mac haha
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
gusm2
