0 A year later...
Last Post: Andy56
Last Post: Sportster25
0 Putting the Sport back in the Sportster
Last Post: gconnsr
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 trimmed shovel top hats
0 shovster ignition timing
0 A few Thoughts
0 Chain: What Type?
Last Post: joe s
0 Amazon CV carb
0 Belt tension
Last Post: 73HEAD
Last Post: Bryan1976
0 Ignition circuit
0 Pipes "Wheezing" on decel
0 Buell XB top end on Sportster Who has Done It??
Last Post: Racepres
0 distributor
0 Rear pulley inner flange
0 spin off
0 Road assistance needed!! (or bike swap)
0 Sportsterpedia Progress
Posted On: 3 Days Ago
0 Rear Brake Hose Discontinued -2003 Hugger
RandallM's Avatar
RandallM RandallM is offline
Other Motorcycle Model: Honda CM450
Other Motorcycle Year: 1982
RandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond repute
I had original bearings with some crud on them and a stuck on tire. And wanted to polish up the aluminum and brake disk.
No, I didn't think to ride it without the beads first, but I do know the wheel was out of balance. I had it on my static balancer, and it obviously had a heavy side.
1995 XLH 883 Sportster Hugger
Originally Posted by RandallM View Post
...I didn't think to ride it without the beads first, but I do know the wheel was out of balance. I had it on my static balancer...
You had it on your static balancer so YOU KNOW it had a heavy side but you didn't balance it using your static balancer?
RandallM's Avatar
Nope. I had an issue with the cones and the dust seals, and a couple of guys mentioned the beads, so I tried them.
Otherwise I would have balanced it myself.
Good for you, they are my go to anymore, no more fugly weights stuck on the rim or hanging off a spoke.
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: XL883 w Hammer 1275
I never heard of these beads but will read up. Just got a new night dragon on the front and I noticed when I got home with the wheel my guy didn’t put any weights on it. Rode for a couple hours and no issues so far.
XLF Rules/Guidelines
XLF Guidelines II
Hammer 1275 w flat top pistons, 07 EFI 1200 heads with Hammer Impact Service, Hammer billet manifold, Stock carb w N65C needle & 45/185 jets, K&N AC, SE 497 Cams, 07+ oil pump w bronze pump gear, Energy 1 clutch w +15% spring, Python 3 Slip ons, Dynatek Ign Module on 28C
rejeanprimeau's Avatar
Tucker use radiator fluid to balance their tire; three once in a syringe and auto-balance.
wtwolf wtwolf is offline
wtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to beholdwtwolf is a splendid one to behold
do you mean antifreeze?
AKA antifreeze, yes
wedge's Avatar
wedge wedge is offline
The reason I asked is because I have never been able to notice an unbalance while riding, even when they were way off, so putting beads in and riding it wouldn't prove anything to me unless I saw the results on a balancing machine. I'm sure a way out of balance tire could show itself under hard cornering over rough pavement, but I think we would all be hard pressed to feel it under most circumstances.
