0 Ironhead XL1000: Cam gear #2 woodruff key broken - Wrong mark on P cam gear
0 Worth fixing?
0 Dino or Synthetic: 1989 Sportster
0 '04 crank in '01 cases?
Last Post: Curbside
0 Burly Stilletto 13" shocks or ?
6 old dude new here
Last Post: Butch 73
0 2016 XL1200CX Parts
0 '67 XLCH stalling out after 15 minutes of riding
Last Post: XLXLXL
7 Hi from Spain
Last Post: 20131200c
Last Post: wolfryder
0 Clutch Spring plate poll
0 Spokes or Mags
7 Where to buy short leads
Last Post: tussuck
0 Triple tree cover question
0 Harley super micron 5 oil filter
0 Upgrade carb kit
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 Video - DK Q&A: Performance 409 Pro-Race Wires OR Harley Screaming Eagle?
0 Bobtailing a sportster
Last Post: Ted Town
phantom, JaggedEdge (76), toe (62), john428 (62), testuser (58), rbuier (47), Insane (45), hdtech237 (42), overland47 (41)
clean, cv carb, diaphragm, no gas, vacuum
Old 30th January 2013
ace87 ace87 is offline
Sportster/Buell Model: 883 sportster
Other Motorcycle Model: Yamaha R6
Other Motorcycle Year: 2008
ace87 is an unknown quantity at this point
Default no gas getting into carb?!
Have a 2000 sporty with a stock CV carb. bike sat for a couple of months during the winter and gas went bad. not my first time cleaning a dirty carb, but first time it won't start after spraying with cleaner and dunking it in seafoam.
after many failed attempts i have noticed that the bowl does not fill with gas at all! the float is not stuck. the float pin is free (moves in and out). gas comes out the tank just fine and uses a gravity fed valve. diaphragm is good. all hoses connected. does there need to be vacuum to fill the bowl? any help is appreciated.
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Are ya certain that ya have enough gas in the tank? I don't know squat about yer year bike, but if you remove the fuel line from the carb and put it in a container, turn the petcock on and it flows, then ya don't have a vacuum operated petcock and ya know that gas is flowing freely.
Look at the petcock. If one fuel line leads to the carb bowl and another leads to the manifold, then ya have a Vacuum tap. Remove from manifold and apply vacuum with yer mouth. No, you won't get a mouthfulla gas! Now fuel should flow.
BTW, I would completely disassemble and clean the carb thoroughly. But that's just me...
