0 Dino or Synthetic: 1989 Sportster
0 Ironhead XL1000: Cam gear #2 woodruff key broken - Wrong mark on P cam gear
0 Worth fixing?
0 '04 crank in '01 cases?
Last Post: Curbside
0 Burly Stilletto 13" shocks or ?
6 old dude new here
Last Post: Butch 73
0 2016 XL1200CX Parts
0 '67 XLCH stalling out after 15 minutes of riding
Last Post: XLXLXL
7 Hi from Spain
Last Post: 20131200c
Last Post: wolfryder
0 Clutch Spring plate poll
0 Spokes or Mags
7 Where to buy short leads
Last Post: tussuck
0 Triple tree cover question
0 Harley super micron 5 oil filter
0 Upgrade carb kit
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 Video - DK Q&A: Performance 409 Pro-Race Wires OR Harley Screaming Eagle?
0 Bobtailing a sportster
Last Post: Ted Town
phantom, JaggedEdge (76), toe (62), john428 (62), testuser (58), rbuier (47), Insane (45), hdtech237 (42), overland47 (41)
btdc, leak, test
Old 22nd July 2016
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant futuregroovemeisterus has a brilliant future
Question Stupid BTDC Question for Performing Leak Tests
If the BTDC line is in the view hole, what is simplest method to find out if it is the Front cylinder or the rear without taking off the rockers?
Could be thinking too deep about it, but seen the following animation and thought to myself I might have had to rotate rear wheel one more time to get the BTDC mark in the view hole again 360 degrees to change from front cylinder to rear or visa versa?
Old 22nd July 2016
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
There are no marks on the stock crank for the rear cylinder at all. All the marks relate to the front cylinder. S&S cranks have marks for the rear cylinder, but not HD cranks.
What you're after is the vertical line. That's the TDC mark for the front cylinder.
But you are correct, just finding the vertical line does not guarantee you're at the correct TDC. Being a 4 stroke motor, the crank makes two complete revolutions to complete all 4 strokes. Therefore it passes through TDC twice.
On one of those TDC's, "overlap" TDC, both valves are very slightly open. Can't run a leak test there! Well, I suppose you could, but both valves will leak terribly.
One full revolution from there, both valves are closed. This is "compression TDC". That's the one you want.
Removing the rocker box to watch the motion of the valvetrain is one way to determine which TDC you're at. However, there's a way to do it without removing the rocker box. Put your finger over the spark plug hole. As you rotate the motor in the forward direction, the compression will (hopefully) blow your finger off the hole. You're on the compression stroke at that point. Proceed until the vertical line appears in the window.
A leak test can actually be performed from about halfway up the compression stroke to about halfway down the following power stroke. That's the window where the cams are commanding both valves to be closed.
Click Here to Contact Me
Old 22nd July 2016
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
dial indicator works best and is most accurate go throw cylinder head.but remember engine cant move after or test is a fail .
