0 TC Brothers weld on rigid on an early frame
Last Post: 71GCcuda
0 Burly Stilletto 13" shocks or ?
Last Post: clif02
0 Sidestand Extension/'Pad' ?
14 What made the best Improvement to your Sporty??
Last Post: wardie
0 switching from 16" to 18" rear tire
Last Post: wardie
0 Cobra fi2000 powrpro black
Last Post: RAIDER0372
0 Jiffy stand spring
0 Spokes or Mags
Last Post: d10221
0 Sissy bar and rack for 883
0 Changed The Fork Oil
0 Ironhead or Evo
Last Post: Andy Hog
0 is a buell a harley
Last Post: 84rzv500r
Last Post: wardie
0 HD announces end of the Sportster model
0 New guy
0 ‘72 Pinion gear question
0 When Were You Born?
0 ironhead oil pump pressure
1250 conversion, leak, mikuni, petcock, vacuum
Old 7th September 2016
sportsterguy55379's Avatar
sportsterguy55379 sportsterguy55379 is offline
Sportster/Buell Model: hugger
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2002
sportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nicesportsterguy55379 is just really nice
Question Petcock leaking
Howdy all, I just got my hammer 1250 kit all buttoned up. As well as the kit I put a Mikuni hsr42 on my bike. After my two mile heat cycle ride I noticed my stock vacuum fuel shut off was leaking from the diaphragm area. I am curious if anyone else has had this problem? I plan on eliminating the vacuum operated Petcock. I will be running the VOES directly to the carb. Any suggestions on a particular Petcock? I did search the forum and didn't find my particular problem. Thanks in advance, this forum ROCKS!!
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
a manual petcock, get rid of the vac petcock
Old 8th September 2016
schollianmj's Avatar
schollianmj schollianmj is offline
Sportster/Buell Model: 98 Sportster 1200
schollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to beholdschollianmj is a splendid one to behold
Yup. Best solution.
mikeLI_77's Avatar
I had 3 out 4 screws fall out on me in the middle of a ride back from Laconia one year. I had to use zip ties to hold it together until I got home. Golan and pingel are to the 2 favorite petcocks for everyone on the forum. Golan has a nice click loco feature that clicks when your on each setting which is a little bit nicer than having to push the lever until you think your there.
2002 XL1200C (originally)
Dyno (96.21 HP / 88.70 TQ)
https://ibb.co/V34RNfc
States I Have rode through
Old 9th September 2016
Sportster/Buell Model: 1200
I installed an Accel high flow petcock last winter, it has a 360 degree adjustable outlet.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You can't go wrong with either Pingel or Golan but, I prefer Golan because of its "click" feature. Excellent quality and just plain works.
Old 10th September 2016
I bought a brass golan. Nice piece. Thanks for the replies.
Old 11th September 2016
splineman's Avatar
splineman splineman is offline
Sportster/Buell Model: XL 90"
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
I just replaced mine with a pingel.....happy with it, a high quality product.
Sent from my Nexus 5 using Tapatalk
2005 Sportster Hammered out to 90"
splineman's Avatar
Oops missed the last post..sorry.
