0 Ironhead XL1000: Cam gear #2 woodruff key broken - Wrong mark on P cam gear
0 Dino or Synthetic: 1989 Sportster
0 Worth fixing?
0 '04 crank in '01 cases?
Last Post: Curbside
0 Burly Stilletto 13" shocks or ?
6 old dude new here
Last Post: Butch 73
0 2016 XL1200CX Parts
0 '67 XLCH stalling out after 15 minutes of riding
Last Post: XLXLXL
7 Hi from Spain
Last Post: 20131200c
Last Post: wolfryder
0 Clutch Spring plate poll
0 Spokes or Mags
7 Where to buy short leads
Last Post: tussuck
0 Triple tree cover question
0 Harley super micron 5 oil filter
0 Upgrade carb kit
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 Video - DK Q&A: Performance 409 Pro-Race Wires OR Harley Screaming Eagle?
0 Bobtailing a sportster
Last Post: Ted Town
phantom, JaggedEdge (76), toe (62), john428 (62), testuser (58), rbuier (47), Insane (45), hdtech237 (42), overland47 (41)
ironhead, magneto, xlch
Old 24th February 2020
panama86 panama86 is offline
Sportster/Buell Year: 1972
panama86 is an unknown quantity at this point
Default Magneto base for 70 XLCH
Hey all,
I recently purchased a 70 XLCH, the crossover year with estart but still had the vertical timer. Previous owner had fitted a Morris mag with a pretty sketchy adjustable adaptor.
I did manage to start the bike but it was too retarded. Due to the sketchy base I am unable to rotate the mag enough to allow for the correct advance. It's also impossible to get to the adjustment nut holding the mag base to the adaptor. Is there an easier setup than this? I'm not fussed with the adjustable advance fixed would be fine. Just not sure what parts I need to buy to set it up correctly. Photos of the adaptor and mag with base attached.
Thanks
Pickss Pickss is offline
Sportster/Buell Year: 1968
Pickss is an unknown quantity at this point
Here is the fixed base style. The two mounting screw holes can be offset or straight depending on the base. Normally available on ebay, vtwin, etc.
OEM #'s 29600-48/29600-62/29600-65C
I've used the style you currently have and not had any issues, but i know the 1970 guys can run into a little more fitment issues.
Hope this helps.
Old 25th February 2020
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Panama, You do not state where the interference is to keep you from setting to Advance ?
Cycle World Oct 1962:
