0 Triple tree cover question
Last Post: RandallM
6 old dude new here
Last Post: Butch 73
0 Upgrade carb kit
0 Bobtailing a sportster
Last Post: Ted Town
0 springer forks rubbermount 04+
Last Post: Butch 73
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 first electrical problem
Last Post: denguy
0 Harley super micron 5 oil filter
0 How do I remove the Rear Caliper?
0 The Strociek Project
7 Hi from Spain
0 is a buell a harley
Last Post: Brad
0 Do you run MAXIMUM PSI?!?
Last Post: Tyler45
0 picked up a nail
Last Post: RandallM
0 How Much Money Has Being An XL Forum Member Saved You?
0 dyna rear on 05 1200c
Last Post: Butch 73
5 Tire Pressure?
0 Spokes or Mags
Old 7th March 2020
ParrotHead's Avatar
Other Motorcycle Year: 1974
Default In Tulsa OK with a bad charging system
Trying to do 6,000 miles in 6 days and lost my charging system Northeast of Tulsa on I-44. Made it to Tulsa.
Issue is intermittent so I suspect regulator is giving up.
Anyone in Tulsa with a spare regulator for an 06 Sporty?
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 7th March 2020
harley506d's Avatar
Sportster/Buell Model: 1200c
Hope someone comes to the rescue mate.
Best of luck.
Old 7th March 2020
Riding with Angels
Chris Martin is over that way "anachris"
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 7th March 2020
Riding with Angels
I have the one off my '06.was good
Old 7th March 2020
ParrotHead's Avatar
Thanks. At the dealer in Tulsa and it is an obsolete part, no longer available from Harley
Old 7th March 2020
Riding with Angels
I could overnight my used one but you wouldnt see it till monday
Old 7th March 2020
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Some local shops all open today.
Contact Mac’s 918-850-7864
Cycle Gear Phone: (918) 384-0608
Can post more
Old 8th March 2020
ParrotHead's Avatar
Update - put regulator in and still not working. Picking up a multi meter to start doing more tests but not looking good.
Old 8th March 2020
Post no Avatars!
Sorry to hear that Chris.
Bad stator is more common I am afraid. Test each lead to ground.
When they fry they short to ground. AC output may look OK but
if shorted to ground it will not charge.
Old 8th March 2020
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond repute
what he said. on the bright side it is pretty easy to change the stator in a sportie.
