Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle General Discussion and Problems
0 Ironhead XL1000: Cam gear #2 woodruff key broken - Wrong mark on P cam gear
0 Dino or Synthetic: 1989 Sportster
0 Worth fixing?
0 '04 crank in '01 cases?
Last Post: Curbside
0 Burly Stilletto 13" shocks or ?
6 old dude new here
Last Post: Butch 73
0 2016 XL1200CX Parts
0 '67 XLCH stalling out after 15 minutes of riding
Last Post: XLXLXL
7 Hi from Spain
Last Post: 20131200c
Last Post: wolfryder
0 Clutch Spring plate poll
0 Spokes or Mags
7 Where to buy short leads
Last Post: tussuck
0 Triple tree cover question
0 Harley super micron 5 oil filter
0 Upgrade carb kit
0 🖥️Cyber Monday!🖥️ Big Savings Inside💰Open for Details!
0 Video - DK Q&A: Performance 409 Pro-Race Wires OR Harley Screaming Eagle?
0 Bobtailing a sportster
Last Post: Ted Town
phantom, JaggedEdge (76), toe (62), john428 (62), testuser (58), rbuier (47), Insane (45), hdtech237 (42), overland47 (41)
horn, lights, no!, start
Old 23rd November 2020
J!nx J!nx is offline
Sportster/Buell Model: S2
J!nx is an unknown quantity at this point
Exclamation 1995 S2 buell
I went to go for a ride the other day and the bike turned over one time and stopped. No lights, horn, or anything. I figured it must be the main breaker, so it was less than 20 bucks so I replaced it and nothing still. I have checked all of the connections and still nothing, no lights, horn ect. My shop manual is deep packed in storage and I need to get this thing running before I move. Could it be my ignition switch? I mean what would cause everything to go blank like that?
If anyone has solved a similar problem I would really appreciate some advice.
All of my tools are packed away too, on my way to Harbor Freight to buy AS test light(but I don't know how to test an ignition key switch.
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
Check battery, if good
clean battery terminals
Steve
'03 1250 NRHS stage two Lightning heads, SE536 cams, mik flat slide 42
'01 Cyclone stock
'13 FXDC 96" stock
I believe it is my ignition switch.
With a test light: 3 wires purple with black tracer
KEY OFF 1 wire receiving power
KEY ON 0 wires receiving power
What do you think?
It is a new battery and I had to remove it to install the new 30a breaker.
Thanks Steve, it is always best practice to start with the fundamentals, I have no way of load testing the battery but I would think it would at least dimly light the headlamp.
Steve9's Avatar
Hi J!nx
Battery could be fine but cables, both at battery and especially where the negative grounds to the frame/motor mount all need to be checked
One of the more electrical guys will have to help you after that
I devised a load test with a Harbor Freight voltmeter and low and behold the new{ish} battery is no good. I have one on order and should be riding Friday, fingers crossed. I have also ordered a new ignition switch, I am afraid the key will fall out of the one I have now.
I have Just put the bike back together(6-8 months ago). I put a 1250 kit on it and a 44mm carb that I had to re jet because I was getting spark knock on acceleration. It has been running fine for about 6 months now. I was sure shit was just wearing out I mean most of it is from 1995.
Steve9's Avatar
Yeh. "new" doesn't always mean good with batteries.
Just don't put many keys on the ring hanging out your ignition. I have my ignition solo for all my scooters.
You probably know that
Old 26th November 2020
Yeah I hate having a bunch of stuff on the key ring.
